Hi all ,
I recently got my hands on a turbo GTP, with the cartuning turbo kit. it has an exhaust leak and i want to replace all of the gaskets. Specifically the rear manifold blockoff gasket, upper to lower DP gasket, and lower DP to catback. Im also open to replacing anything else you folks suggest .
Im assuming that the rear exhaust manifold gasket is just the OEM gasket, even when using the ported rear mani. The ones im not sure about are upper to lower DP, and lower DP to catback. can i just use a normal 2.5 inch exhaust flange gasket?
