Thread: Ran out of Injectors E85 80#s
Results 1 to 7 of 7
  1. #1 Ran out of Injectors E85 80#s
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Made 522WHP on the dyno last weekend @20psi and 18deg on corn. Prob would of got more greedy if I didn't run out of injector and was worried about my drive chain letting loose. I have somewhat of a plan for my trans to hold and would really like to hit 600 whp mark just because. Can anyone recommend what injectors they've used past 80#s? my 340lph pump is maintaining 60psi under wot but dont think its capable of much more or I would just turn up the FPR.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Ran out of Injectors E85 80#s
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Good numbers, post video/chart for drooling. Not sure if you want to go for the 95# Low-Z (RX) or Hi-Z (Texas Speed shows some), try ZZP's 160# option, or other.
    PM me if you want to sell your 80#'s, as my 60#'s with my Bosch 4bar FPR will probably start hitting 20+ms IPW's as I push pump gas (use 110 for racing, but that's Ludicrous mode).
  3. #3 Re: Ran out of Injectors E85 80#s
    Nebraska
    I will get vid up tonight, nice thing about the 160#s i could just double my IFR if the table even goes that high i thought maybe i had problems with scaling a while back above a certain number. Seems 160#s might be a bit overkill tho too.
  4. #4 Re: Ran out of Injectors E85 80#s
    Banned
    May 2008
    Max value is almost 10x stock, and having to skew it to not outflow your MAF table should keep you more than OK. All trial & error, though. Crawl-walk-run, as is tradition.
  5. #5 Re: Ran out of Injectors E85 80#s
    Nebraska
  6. #6 Re: Ran out of Injectors E85 80#s
    Banned
    May 2008
    Sounded great, good job. You inspired me to look up shops where I'm at to head there when I'm ready.
    Keep the updates coming.
  7. #7 Re: Ran out of Injectors E85 80#s
    May 2008
    Schuyler, NE
    95's are what my buddy ran, til he maxed those.
  1. l67 injectors and tb on l36
    By l67ss in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2013, 09:30 AM
  2. 42# Injectors
    By dbextreme in forum Wanted To Buy - Parts
    Last Post: 02-16-2013, 02:23 PM
  3. Injectors
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2013, 10:30 AM
