#21
Re: Turbo planning and questions
If its not raining tomorrow...I'll probably do that and
finish the lower intake/upper.
Intercooler came tuesday, so i need to mock it up and
get an idea. From the looks of it. The f-body icm rail
would go where the egr sits, so i'll take that off as well
#22
#23
01-04-2020
#24
aint the size of the boat
#25
42# can go fairly far. I was near 400whp on the 42.5# injectors. also im over in Lancaster, pa seeing that you're over in Baltimore.
#26
Cool, thats whats up. Think you can come help a brother out?
Getting my powerlog re-welded and wastegate attached then i
need to button this bad girl up by March
#27
you're in Baltimore, a bit of a trip lol.
#28
Aww, it aint that bad.. i'll pay for the time and assistance
#29
#30
01-27-2020
#31
#32
01-27-2020
If you flipped your oil line you would probably save 18" in length
#33
ItHurtz
Ha, yea the original line was literally 3' short, so i purchased another and somehow
it was equal length. I'm feeding from the oil filter adapter so, i needed a little more
rope. I just put them together
Front p-log/wastegate setup should be finished welding tomorrow. Pedestals for the
roller rockers be here next week, then i need to button it up and relocate the battery
to the trunk. Get the blockoff plate for the rear manifold i could have it out by mid-February
#34
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#35
01-29-2020
Are the welds atleast free?
#36
ItHurtz
Yes, he didn't charge me for it. Going to need to shave some
of the fan shroud down for it to go in freely. Try to get that done
the weekend, weather permitting.
#37
Donating Users
01-30-2020
You can also cut and reweld the brackets for the fan at the top and reweld them about an inch shorter to pull it in further.
Top Swapped 01 Imp
#38
01-30-2020
Waste gate going to be a open dump?
#39
Ok. Ill look into moving the fan in closer. It's literally like an inch too far out.
I have the pipe for the wastegate dump. After I get it hooked up I'll see if it's going to fit without issue
#40
