Thread: Thinking about More Power/Future Mods
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Thinking about More Power/Future Mods
    Aug 2016
    MN
    That part wasn't particularly hard. Since the tangential housing drops the exhaust outlet an inch or two over an on center housing, I cut welds on the bottom where the pipe feeds the flange and angled the flange up to compensate. Some guys have problems with the downpipe being too close to the master cylinder anyway, this will only help with that. Is your pt61 rebuildable? That would still be cheaper than a new one.
  2. #22 Re: Thinking about More Power/Future Mods
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    No it's shot based on the amt of shaft play I have plus I need more boost lol. You have any pics?
  3. #23 Re: Thinking about More Power/Future Mods
    Aug 2016
    MN
    Unfortunately I didn't really take any pictures of the modifications I made. But what I did was mount the crossover and the downpipe, put bolts loosely in the top two holes of the flange to hold the new turbo in place and then just eyeballed how much I needed to turn it up. Once done, remove crossover, cut the bottom and weld it again. I had about a 3/8" gap on the bottom, so i used a scrap chunk of stainless pipe as a spacer. I don't think the 6262 has a 4 bolt housing o ption so you will probably need to convert to Vband.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  4. #24 Re: Thinking about More Power/Future Mods
    Nebraska
    I wish a had a tig welder that's where my problem lies. What kind of boost is that turbo capable of?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  5. #25 Re: Thinking about More Power/Future Mods
    Aug 2016
    MN
    Get it how you need it and bring it to your local welding shop. A steel supply shop a block down the road did mine for like $30. As far as boost, what do you want to run?
  6. #26 Re: Thinking about More Power/Future Mods
    Nebraska
    Currently at 15psi but that's everything i can get out of my pt61 I need to be about 20 with no additional timing and have a boost controller that allows me to go to 23 or so when I want more power as long as everything looks good.
  7. #27 Re: Thinking about More Power/Future Mods
    May 2008
    Schuyler, NE
    Are you sure you have enough wastegate spring? My buddy's car was running 24psi on his pt61.
  8. #28 Re: Thinking about More Power/Future Mods
    Nebraska
    Yeah it's just because it's on it's last leg the turbine literally rubs the housing with no oil pressure on the needle bearings plus this motors flows very well.
  9. #29 Re: Thinking about More Power/Future Mods
    Aug 2016
    MN
    Quote Originally Posted by 94GrandPrixSE View Post
    Ouch! I'm thinking of hitting 20 myself on this once I get everything else done. Not sure why you couldn't hit that or higher.
  10. #30 Re: Thinking about More Power/Future Mods
    Nebraska
    Is the turbo you used a T3 .82 vband 6262?
  11. #31 Re: Thinking about More Power/Future Mods
    Aug 2016
    MN
    No, the cartuning kit uses a T4 flange, so I used the T4 .58, it builds boost very quickly, but if you want bigger numbers you might want the .68
  12. #32 Re: Thinking about More Power/Future Mods
    Nebraska
    So you just change the on center flange?
  13. #33 Re: Thinking about More Power/Future Mods
    Aug 2016
    MN
    Yup the 4 bolt downpipe flange. Precision uses an off size vband clamp that you can only get from them. Supposedly others will fit okay, but I haven't tried them myself
  1. Future Visual Mods
    By Ksirb in forum Visual/Body Modifications
    Last Post: 02-05-2013, 07:33 PM
  2. Future Mods, looking for opinions!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 06-29-2012, 01:12 PM
  3. Future Mods... what to expect
    By T0pwater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2011, 03:52 PM
  4. Thinking about the future...
    By Odi in forum General Tech Discussion
    Last Post: 08-18-2009, 08:42 PM
  5. Future mods questions
    By nascartech in forum Introductions/Noob Questions
    Last Post: 03-30-2009, 02:49 PM
