Thread: Just got a turbo kit, couple quick questions
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 101
  1. #81 Re: Just got a turbo kit, couple quick questions
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Quote Originally Posted by ItHurtz View Post
    War is N/A, there are no upgrades for his car. His wife lets him buy windshield wipers and air freshners, he... is not a man.
    nope, not at all...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #82 Re: Just got a turbo kit, couple quick questions
    Antioch, IL
    I can get you pics of Nitrous if you want, doesnt mean anything though.
    2009 Challenger SRT8
    Expert at being gay.
  3. #83 Re: Just got a turbo kit, couple quick questions
    Oct 2014
    Frederick, MD
    I can get pics of anything else as well, doesn't mean this isn't sitting in my lap right now.
  4. #84 Re: Just got a turbo kit, couple quick questions
    Sep 2015
    Richfield
    I'm still waiting for the day that ItHurtz says anything meaningful and helpful.
    Sent from my LGLS675 using Tapatalk
  5. #85 Re: Just got a turbo kit, couple quick questions
    Sep 2015
    Richfield
    If I wanted to hear sarcasm and bad comedy I'd watch a Dane Cook skit.
  6. #86 Re: Just got a turbo kit, couple quick questions
    Sep 2015
    Richfield
    I wish you lived in MN and I could line up with you in my turbo L67 haha haha 😁😁😗
  7. #87 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    So I've been doing a lot of research and I can't decide what UIM, TB, & MAF combo I want to use. Has anybody used an L36 UIM on a turbo setup, hopefully not with explosive results?
    Someone mentioned using an LS7 MAF, has anyone successfully used/tuned one? The small amount of research I've found seems to indicate they are a bit touchy and can be difficult to tune. How much boost is the LT1 Maf good for without a mini afc?
  8. #88 Re: Just got a turbo kit, couple quick questions
    Kemmerer, Wyoming
    If you are supercharged already, just use a block off plate.
  9. #89 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    I have two different cars, this one is an L36. I need to make a signature, lol.
  10. #90 Re: Just got a turbo kit, couple quick questions
    Kemmerer, Wyoming
    Just keep the plastic upper intake, plenty of people have used them with no issue.
  11. #91 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    Quote Originally Posted by SgtMarshal View Post
    I'm a big fan of that idea. Everything I've read is that the L26 UIM is just kind of a pain. I will probably plug the coolant holes however, just in case.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  12. #92 Re: Just got a turbo kit, couple quick questions
    hangover park IL
    plug TB coolant holes with 1/4" npt, remove side cover and use a 4.5" grinders 1/4" wheel to grind a 5/16ths deep 1/4" wide trough through the divider to restore coolant flowuse stock tb/maf, use afc scaling if your able to hit close to 11khz
    ~James~ Psychotic Gearhead
  13. #93 Re: Just got a turbo kit, couple quick questions
    Kemmerer, Wyoming
    Quote Originally Posted by Mitch R View Post
    switching from an L36 to an L26 is more hassle than it's worth. if your L36 fails, it might be worth considering, but otherwise, I wouldn't bother.
  14. #94 Re: Just got a turbo kit, couple quick questions
    hangover park IL
    inspect the area around the EGr stovepipe near the TB coolant passages, if there's any evidence of erosion/overheating at least plug the tb coolant ports and egr
  15. #95 Re: Just got a turbo kit, couple quick questions
    this is your warning vet, dont come back.
    your not funny nor are you wanted around here. keep it up.
    yes scott edited your crap post. now contribute or stfu!
  16. #96 Re: Just got a turbo kit, couple quick questions
    Or because you couldn't make up your mind and blew up too many motors but whatever ya know.
    You brought alot of the drama on yourself anyway.
  17. #97 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    So I've been trying to decide on exhaust manifolds. I should just change the thread title to Mitch's Neverending Turbo Build Questions.
    For the front it seems that the ZZP Plog is my only option, but from what I've read it is definitely worth it.
    For the rear there seem to be a couple different options but I haven't been able to find anything that seems to indicate what works best. I've seen some that have kept the stock rear manifold and turned the tube on the #6 cylinder, which makes sense, but I'm not very good at fabricating so I would have to pay someone to weld it. ZZP has the turbo rear plog but that would require relocating the wastegate since I have the Cartuning kit. The third option would be the ZZP NA Rear Plog that still has the downpipe opening for the wastegate perch. Of course I could just leave it alone, especially if none of these choices make much difference anyway.
    I measured the ID of the pipes on the Cartuning crossover they are about 1 7/8, so a manifold any bigger than that likely won't make much difference. My eventual goal is 350 - 400 hp.
    Those of you that have done any of these or remember folks that did, what worked best or was most cost effective?
  18. #98 Re: Just got a turbo kit, couple quick questions
    May 2008
    Schuyler, NE
    For 350-400hp, there is no reason to run anything other than stock manifolds.
  19. #99 Re: Just got a turbo kit, couple quick questions
    Oct 2014
    Frederick, MD
    Get the front plog and leave the factory rear, you won't need better that that for a very long time.
  20. #100 Just got a turbo kit, couple quick questions
    Quincy, Mass
    Wait for Black Friday and get the rear NA plog cheaper, I got it for $190-$200 last year.
    No more GP 04 Impala SS Indy:
  1. Couple of quick questions
    By SpecialK in forum Introductions/Noob Questions
    Last Post: 01-15-2015, 08:14 PM
  2. Couple quick questions
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 06:30 PM
  3. couple of quick questions about tstats
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 02-02-2010, 11:05 AM
  4. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  5. couple of quick downpipe questions.
    Last Post: 03-18-2009, 07:36 PM
