Thread: Idle surge causes?
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Idle surge causes?
    Sep 2015
    Richfield
    Wow! I was just simply stating that I was looking for advice, not criticism. Why is it that you know it all, but can't offer me simple advice Scotty? There's much reward in being humble, maybe one day you'll learn this. I've been taking pics of my entire build, and wanted to do a full build post. I have the exact opposite of a "sloppy mess", I just wanted to post everything when it's driveable. Sucks that I've put over $12,000 into everything to be belittled over an idle surge. Not saying, just saying.
  2. #22 Re: Idle surge causes?
    Quote Originally Posted by CrazyGuy03 View Post
    Wow. Didn't see that coming.... Zero fcks given now. Good luck!
    X2. could f ing care less. have fun with your messed up build. if your lucky you didnt just piss everyone else off.
  3. #23 Re: Idle surge causes?
    Quote Originally Posted by GTPChristopher View Post
    maybe you should have documented your build while you did it, so you could of had help...but your to good for that crap lol
    12 g's, what you f ing smoking over there? send me 5 bucks worth will ya.
  4. #24 Re: Idle surge causes?
    hangover park IL
    If that o2 is stock. ..get a new one.
    Like the maf it is a trusted sensor which means that the degradation overtime is not noticed or diagnosed by the PCM.
    If that O2 sensor has 50000 miles or more it should be replaced with a new Denso, Delphi or AC Delco narrow band sensor.
    do not buy the Bosch
  5. #25 Re: Idle surge causes?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    how about instead of snarking at him let's be a little more analytical in the approach.
    let's ask "how does the PCM set the P0300 code?" it looks for excess oxygen in the exhaust stream and knowns which cylinder fired when it saw the lean condition. (remember, a misfiring cylinder will have *excess* oxygen and read lean to the O2 sensor, not rich, because the unburned fuel did not consume the oxygen in the cylinder). If its a random misfire on all cylinders then the cam could absolutely explain the P0300 code, you have enough overlap on each cylinder that some fresh air is getting into the exhaust and the PCM interprets it as a misfire.
    what causes surge? the PCM is cycling the IAC valve in response to *something* because it thinks the mixture is wrong (i.e., O2 readings are not responding as expected) for the given RPM, MAFF, and IPW. Vacuum leak can cause a lean condition, PCM blasts the IAC closed to richen up, then it's too rich, so it opens it again, etc.
    taking both of these together: check for obvious and non-obvious vacuum leaks. all hoses, MAFf sensor gasket, EGR tube. Even injector O rings. make sure the O2 sensor wiring is not being rubbed or burned. Make sure the O2 is in the right place and is getting hot enough. then try a new O2 sensor.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #26 Re: Idle surge causes?
    Kemmerer, Wyoming
    last night we talked about the tune in the chatbox, and another likely cause is that the tune might not have adjusted for the 2 bar map sensor now installed. we are talking about a zzp canned tune, so in my opinion, adjusting the tune for the different map, and doing a maf sensor adjustment on the car should make a huge difference, at least it should unless there really is something wrong with the car. and the P0300 should also be disabled.
  7. #27 Re: Idle surge causes?
    Mar 2014
    Tucson
    Does it surge on P/N only? What happens when you drop it in gear?
  8. #28 Re: Idle surge causes?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    My car is doing the same thing as his. The surging only occurs in P and N.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  9. #29 Re: Idle surge causes?
    Apr 2014
    South Haven, MI
    Figured it out. On my car, the vac line to the evap system had a huge hole causing a terrible vac leak
  10. #30 Re: Idle surge causes?
    Quote Originally Posted by BoostedPontiac View Post
    ding ding ding lol not a tune issue for sure on your car.
  11. #31 Re: Idle surge causes?
    Buffalo
    I've heard about using the 1/8th hole
    in the throttle plate for North Star throttle bodies helps the iac hunting
  12. #32 Re: Idle surge causes?
    why not just delete all the evap codes and cap off the port for it on the tb. did that like 3 years ago now.
  13. #33 Re: Idle surge causes?
    Apr 2014
    South Haven, MI
    It was bugging the hell out of me. One minute it was fine, the next minute it fluctuated like a Mofo.
  14. #34 Re: Idle surge causes?
    Apr 2014
    South Haven, MI
    What about the line that goes to the venturi bucket? Cap that off too?
  15. #35 Re: Idle surge causes?
    i took the purge solenoid off and the line for it just hangs out back there open to air with no fvcks given lol all 12 codes iirc are deleted.
    i had evap codes due to a large leak, so instead if fixing it i deleted it all. i later found the filler vent tube was rotted and fell off. im sure that was the issue. ive since fixed that cause i was smelling gas from it, why it was found, you smell gas you start to look for things.
  16. #36 Re: Idle surge causes?
    Sep 2015
    Richfield
    Turns out that a simple MAF replacement solved the surge. Strange thing was that it was working perfectly okay last year before my teardown. Just went to show me that everything needs to be questioned when changing everything lol
  1. A/C makes cars idle surge
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 08-30-2014, 01:19 AM
  2. Idle Surge
    By Huckleberry in forum Engine
    Last Post: 12-30-2013, 01:00 PM
  3. RPM Surge
    By whiteknuckle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2011, 10:58 PM
  4. Say no to surge
    By Switzersland in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-10-2011, 10:29 AM
  5. Another idle surge/misfire problem with multiple codes
    By Justinzoso in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2010, 11:43 AM
