Im pretty sure people have done this in the past. Is there a write up on how to make the anti-lag switch using a relay and some resistors?
Just need a momentary switch either you hold and press.. or rig up to brake pedal.
When pressed in, cuts signal of IAT...
Drops to -39
Adjust your IAT table to knock timing down to nothing.
when you let go of switch, IAT is back to working order and timing restores to normal.
Well that seems simple enough. Thank you.
