Thread: My Build progress 56k no way
Results 1 to 13 of 13
  1. #1 My Build progress 56k no way
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    All on a college student budget woot! lol Practically stealing the parts haha.
    My build well In progress piecing it together. Still need a Tial 50mm bov, turbo blanket, and TUNE other then that I have everything.
    Just the parts for now Ill be installing Late feb early mar
    10psi for now till I build / buy the trans. (Before you all spaz about omg trans omg omg....... I have funds just in case)
    For now just a fun daily. Once I save up more then Ill do my serious build. Engine Trans etc
    Ok here we go!
    Here is the first box:
    Everything was ceramic coating but its wearing off. Ill be wraping everything.
    Here is the crossover pipe for m exhaust manifolds and the turbo exhaust down pipe.
    Here is the Turbonetics Evolution wastegate and the throtle body charge pipe. (charge pipe will not be used once the intercooler comes in)
    Here are the feed and return lines, the boost controller, the breather, and the oil catch can, Bov-- getting a 50mm tial for the intercooler
    Here is the downpipe
    And the best part the PT-61 turbo
    T4
    and here is the mess I had to clean up...
    Continued next post
    Speed is an addiction the faster you go the slower it becomes.
    01 GT | Matt's new TT cam | PT-67 | 18-22psi and a couple stock trannys.
  2. #2 Re: My Build progress 56k no way
    Nov 2008
    NY
    Part 2
    Two days later
    Ill be cleaning everything up then bringing the piping off to paint. (Family friend does great work)
    We will be treating etc then sprayed.
    The stainless piping will be done in a candy apple red but a little darker or I might just do black idk yet
    the Black piping will just get a black re-spray. Ill be buying new couplers later on too.
    I'm storing everything in the back corner of the basement lol
    Getting the 65# injectors in next week. Im looking on supra forums Ive had a few offers for the tial but way to much on there.
  3. #3 Re: My Build progress 56k no way
    Nov 2008
    NY
    I have 1 question what is the Lq4 maf good up to? Also LQ4 vs LT1 etc
  4. #4 Re: My Build progress 56k no way
    Donating Users sra_chipmunk's Avatar
    Georgia
    Quote Originally Posted by ChrisGTT View Post
    A stock Maff will work plenty for this setup. I dont beleive anyone would recomend the LQ4 MAF over the stock one for a turbo setup. I had the LQ4 Maff on my SC setup but when I went turbo, I sold it and returned the stock one in its place.
    Yeah its a grand prix, so what, wanna fight about it.
  5. #5 Re: My Build progress 56k no way
    SE Level Member Sinister Drag Designs's Avatar
    You can get away with the stock maf for a little awhile. Th LT1 Maf is a nice choice because of the headroom over the stock maf and LQ4. Also with the heat of the turbo and IC piping size the LT1 is a good choice. There is ways to rework the stock maf. You can use the 99+ stock maf in a larger housing(DIY), or use a AFC 1.1 or newer to scale the freq. back.
    Another option outside of that is trimming the bottom plastic off the maf. Easy to do with 97-98style mafs.
    Just a heads up from a former CT owner. You might want to consider swaping wastegates if its in the budget. Once you starting running higher boost the evo will give you boost creep and overall odd boost fluctuation that you will never be able to fix without swaping wastegates. This isnt just on 3800 kits, alot of EVO wastegate owners have this problem. Its only a 35mm wastegate, not a 38 like most say. Also if you can blend the wastegate inlet tube that mates to the rear mani it could help some. Outside of a noise gain, an open wastegate dump would not be a horrible idea. Before the install is done mounting a homemade Co2 sprayer or water mister for the front mount would be good for cooling would be a nice thing. easier to figure out mounting before you finish the install of the front bumper. Also insulating your cold side piping in the fender well from your hotside. You dont have to do it the whole run but where they touch for mounting gets a little hot. Also if your sticking with the stock radiator think about a pusher fan behind the IC for extra air to the radiator and ac condensor.
    Good idea on wraping and the blanket. the coating on the crossover and DP is nice for heat but header wraping both will make you alot happier if you ever have to work on the car less then 3 hours after driving.
    What are you doing for an air filter?
  6. #6 Re: My Build progress 56k no way
    Nov 2008
    NY
    K&N cone idk how I am going to work the tubing yet.
    Ive been looking into Tial WG on supra forums same with the BOV. I'm still buying parts for the kit. lol
    For now its just going to be a fun DD till I save up a good amount of funds and go nutty lol.
  7. #7 Re: My Build progress 56k no way
    I live here. UR LOSN's Avatar
    Rockford, IL
    Tial FTW!
  8. #8 Re: My Build progress 56k no way
    Topeka, KS
    Looks fun I'm sure you will enjoy!
  9. #9 Re: My Build progress 56k no way
    looks like a nice build coming. im a turbo noob, but where do u tap for the oiling of the turbo? im always pondering the idea of going turbo but stuff like where the oil feed/return lines go as well as figuring on the vac lines and adjusting the wastegate(or using a manual boost controller?) gets me all confused. *subscribed so i can learn more about turbo setups
  10. #10 Re: My Build progress 56k no way
    Nov 2008
    NY
    No tapping at all bro! It uses the sending system that is already in place.
  11. #11 Re: My Build progress 56k no way
    Rockford, IL
    Quote Originally Posted by fst View Post
    At the back of the motor down by the oil filter is your oil pressure sending unit. this is a standard NPT fitting. just get a T fitting and an extension..and run the line to the turbo. you will retain the sending unit and have an oil supply line.
    the return line...... I have mine where the level sensor used to be....again. its an NPT fitting.
  12. #12 Re: My Build progress 56k no way
    any updates on this build? and pics XD
  13. #13 Re: My Build progress 56k no way
    Nov 2008
    NY
    Yep. Im picking up a set of 65# injectors sometime this week or next locally. And I will be getting a Tial Q 50mm Red Anodized BOV. Once I get those in then all I need is a tune and I should be good to install.
    I got the al103's gaped at 45, Throtle Body Gasket etc a few days ago. Nothing big but since you wants pics :P
    Here are the injectors I am picking up. Less then 3k on them. Ill take pics once I get them.
  1. 280-340 HP build
    By patturlington in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 02:33 AM
  2. Help fast! lim gaskets in progress
    By speedemongtp in forum General Tech Discussion
    Last Post: 01-02-2009, 01:48 PM
  3. build in progress
    By sra_chipmunk in forum Off Topic Discussion
    Last Post: 06-11-2008, 07:09 PM
  4. work in progress
    By Chleby in forum Audio, Security & Visual Electronics
    Last Post: 04-12-2008, 07:29 PM
