I'm just finishing up my t67 turbo build on my l67 with an l26 mani and need some help with the vacuum routing. I'm running stock l67 TB, MAP, and fuel rails. Anyone have any diagrams?
i used a vacuum block made it easy. you can block off the l26 evap port and use the l26 map hold plastic piece, tap it and put a brass nipple on there it works nicely.
http://www.clubgp.com/newforum/tm.as...665610#5530695
Log into clubgp and then click the link, should work
or search L26 UIM Vacuum Routing Diagram by baddestgtp
