Thread: got a race comming up
Results 21 to 40 of 52
  1. #21 Re: got a race comming up
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    We have a guy here running a 3.4 with no problem at all on his 04+. Where did you get that from? I may be wrong but your tune has to be insanely rich to be maxing injectors so early.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  2. #22 Re: got a race comming up
    GT Level Member gtphayes's Avatar
    Nov 2008
    harpers ferry, Wv
    hmmm. maybe you should take it to someone with a welder near you? that was kinda my plan if i got those headers. or maybe someone on here knows exactly what size clamp you need.
    ---under construction---
  3. #23 Re: got a race comming up
    Donating Users blowfishRus6's Avatar
    g.a.
    ive heard it from a few different people on another forum. thats what they say the aeroforce reads. also will at overkill told me this. its okay i can wait on some injectors. i should have been in the 13's with just my intake and headers (slick street tires suck at the track) i think ill have him coverd with rockers.
    and about the exhaust, i had it tack welded, but when its on the car you cant really get the top side of the y pipe. im going back to them and see if they got some clamps i can use. im sure they can make something work, just gotta have the time to get out there :/
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #24 Re: got a race comming up
    g.a.
    anybody had anyluck useing seafoam?? do you put in your gas, oil???
    its slow.
  5. #25 Re: got a race comming up
    GXP Level Member ryangtp89's Avatar
    Maine
    My next mod is rockers this spring, I know im gonna need spring, so i was wondering what else do i need and what size should i get that would go good with my mods i have now. so should i get like 1.84 or 1.9 or 1.95 ???
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  6. #26 Re: got a race comming up
    g.a.
    they say you can use stock springs with the moded 1.9's. the yella terra 1.84's are rollers, dont really know the gain between roller and non roller but you can use the stock springs with those also. if you go above 1.9 then you need springs
    its slow.
  7. #27 Re: got a race comming up
    Maine
    But wont I still get valve float if i do go with 1.9's and keep the stock springs ? If not that would b nice and that would save me some cash. I got my eyes on the zzp 1.9 mod rockers for 274.99
  8. #28 Re: got a race comming up
    g.a.
    as long as you dont go much over 6000. i wouldent go over 6000 just to be safe. and they had them for 200$ on black friday. im hoping they will have a christmas sale.
    its slow.
  9. #29 Re: got a race comming up
    Donating Users
    W-S, NC
    Quote Originally Posted by blowfishRus6 View Post
    X2!
  10. #30 Re: got a race comming up
    g.a.
    im mad i dident get them on black friday :/ but i wanted a damn cam.... idk i might change my mind again by then
    its slow.
  11. #31 Re: got a race comming up
    Maine
    hahaha im always going over 6k, the shift point is 6500,looks like im gonna need the springs.
  12. #32 Re: got a race comming up
    g.a.
    then you DEFF need some springs!!!
    YouTube - Valve Float
    valve float causes because the the springs are moving to fast and cant keep up. stiffer stronger springs take care of that.
    its slow.
  13. #33 Re: got a race comming up
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    He was sand bagging you, that car should be in the 13's easy w/ a retarded driver.
  14. #34 Re: got a race comming up
    g.a.
    its possible but he dident know anything about our race till after he went to the track. so not really a need to sandbag. he then said in a kill story that he raced a gtp and put a couple cars on them (anyone that lives in gainsville georgia that raced an iroc latly??), hence why i called him out.
    i heard him going down the track and he was in it. he did have his dad with him and he "says" he has 300 pounds of stero equipment in the trunk but who knows.
    its slow.
  15. #35 Re: got a race comming up
    g.a.
    we'll know for sure in a few weeks tho
    got my coolent elbow today, hopefully that stops my leak.
    went to two muffler shops today and neither one had band clamps to fix my exhuast leak so im still looking for that
    its slow.
  16. #36 Re: got a race comming up
    Feb 2008
    Houston
    Why are you shifting that high? With an ic, rockers, dp, and 3.0 pulley i felt like i was overrevving and making not much power.
  17. #37 Re: got a race comming up
    Maine
    Quote Originally Posted by t24moore View Post
    who me me???? i'm not 100% sure if it shifts to 6500 at wot, cause i havent driven it in a few months, but it has the zzp pcm in it soo what ever they have it set at thats what my car shifts at. But im pretty sure it shifts past 6k.
  18. #38 Re: got a race comming up
    g.a.
    yea your really not making any power up there. the gen III, stock cam and stock heads run out before that. rockers wont make up enough for that.
    is that how the tune comes from zzp???
    its slow.
  19. #39 Re: got a race comming up
    g.a.
    i think zzp is set at 6k but it usally takes the tranny a few hundred rpms to shift. but idk you do have a triple edge tranny.
    its slow.
  20. #40 Re: got a race comming up
    Maine
    I'm pretty sure the rockers will improve my performance.
  1. How bad is it to race in...
    By GTP4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2008, 08:27 PM
  2. race pellets
    By 1badgp in forum PCM Tuning
    Last Post: 09-27-2008, 04:15 PM
  3. race fuel
    Last Post: 07-11-2008, 08:49 PM
  4. funny race
    By stlmo_gtp in forum Track Sessions and Kills
    Last Post: 04-10-2008, 11:13 AM
