Thread: s475 track weekend begins
Results 1 to 9 of 9
  1. #1 s475 track weekend begins
    Feb 2009
    flintnasty MI
    Starting off now... heading to norwalk for the dsm shootout weekend.
    Installed my much bigger turbo and nitrous this week. Tested it yesterday and it exceeded my expectations.... 25% more power than I ever had and 35% more than I had last year at pont nationals.
  2. #2 Re: s475 track weekend begins
    Moar boost.
  3. #3 Re: s475 track weekend begins
    Apr 2011
    Vassar, Mi
    Sweet, you running test and tune Sunday? We will be at econolodge with the GTP.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  4. #4 Re: s475 track weekend begins
    Feb 2009
    flintnasty MI
    going to try to run as much as can. at motel 6
  5. #5 Re: s475 track weekend begins
    Apr 2011
    Vassar, Mi
    If its the same setup as last year there will be lots of open t&t on Saturday while they run the auto cross and max effort stuff. There usually isn't much time for t&t on Sunday. Too bad you didn't make it down for buschurs sport compact event in May, there is classes you could have run the car in at that one. I won 2nd place in the Bracket 2 class, was the only 3800 running. He cancelled that for next year because of low turnout.
  6. #6 Re: s475 track weekend begins
    Feb 2009
    flintnasty MI
    runs today good 2 runs one shakedown and one full boost 13psi and 138mph.
    Threw some oil out the breather but it doesnt seem to be broken.
  7. #7 Re: s475 track weekend begins
    Feb 2009
    flintnasty MI
    The bad luck continuned to flow, and I basically just gave up and partied/hung out the rest of the weekend.
    1. Found a wasp nest in my new wastegate reference line, caused me to overboost by 15psi (140% Injector duty) 3 test and tune runs.
    2. Randomly threw oil out the rear breather in return road.
    3. Randomly threw a coolant plug on the ground when pulling into my pit spot, requiring me to go to autozone to get a new one.
    4. The second I unloaded my car off the trailer on friday, the shifter link broke, requiring me to pour JB weld all over it.
    5. EVERY DAMN TIME I tried to launch i was racing against someone that didnt know how to drag race, causing me to melt my trans... Never got a good test launch.
    6. Both rear motor mounts are shot, causing some vibrations at 140mph I didnt like and unknown other problems.
  8. #8 Re: s475 track weekend begins
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Ah that sucks, was looking to see you post some positive results but as the old saying goes..."Thats Racin"
  9. #9 Re: s475 track weekend begins
    Feb 2009
    flintnasty MI
    Quote Originally Posted by 231FUN View Post
    I was more excited about trying to get the c16 setup in there for my first full run... I expect some crazy things.
  1. 2000 GTP: Still Alive! New Trans?
    By Booba5185 in forum Members Rides
    Last Post: 10-07-2018, 12:28 AM
  2. Method to my madness, Build begins for the GTP
    By Stinkygrub in forum Engine
    Last Post: 02-24-2012, 12:40 AM
  3. And ... it begins.
    By jdwyat in forum General Tech Discussion
    Last Post: 08-26-2010, 10:30 AM
  4. track this weekend!
    By 2000GTP in forum Off Topic Discussion
    Last Post: 11-16-2009, 03:09 PM
  5. Audi Track Weekend
    By FastKatt in forum Shows and Events
    Last Post: 02-27-2009, 11:45 PM
