Thread: New car first time going to the track
Results 1 to 20 of 23
  1. #1 New car first time going to the track
    SE Level Member evand's Avatar
    Jun 2013
    United States
    Well I just got my 01 grand prix cleaned up. It's tuned pullied and intake by prior owner. I am going for a base line before I install headers, cam and my own tune (hp tuners on the way) Exploring intercoolers.
    What is your 1/4 technique. I am used to my truck with AWD brake stall and go.
    what are you doing at water box on street tires? completely driving around it and no burn or pulling right thru and e-brake burning the front.
    Brake stall or not for best 60 time. a little loading with the gas or just stop on it at the lights.
    My car
    Uploaded with ImageShack.us
    my normal track machines
    Uploaded with ImageShack.us The truck is the sleeper of the group it has the most mods and a tiny amount of nitrous. I hate the camaro on the track with 4.10's, 6 speed and all season tires it's never gonna grip the whole length of the track.
  2. #2 Re: New car first time going to the track
    Apr 2011
    Vassar, Mi
    On street tires? Drive around the box. Bring it up to about 1200 rpm on the brake then roll into the throttle slowly cuz it's gonna spin.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  3. #3 Re: New car first time going to the track
    Texas
    ZZP has an article on this:
    Drag Racing Tips | ZZP News
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: New car first time going to the track
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    in for more tips.. going for the first time tomorrow! can never hurt to get more tips
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  5. #5 Re: New car first time going to the track
    Banned
    Jan 2013
    Colorado
    Don't go through the water box on street tires.
  6. #6 Re: New car first time going to the track
    Jun 2013
    United States
    Quote Originally Posted by camopaint0707 View Post
    I have watched a hundred civics do this before. Never go to import wars.
  7. #7 Re: New car first time going to the track
    Grand Island, Nebraska
    My track makes you go through it and spin just a little to get the gravel and stuff off your tires, I don't really have a problem, but I'm going to try not to next time. I would hold the brake and rev it to 1500-2000 and then let off the brake and slowly go into the throttle. You want your tires to chirp just a little bit so you know that you're pushing it to the limit. It will take practice. If you're really ballsy you could use the parking break instead of the regular brakes to preload the rear suspension.
  8. #8 Re: New car first time going to the track
    Search on spring blockers and cable mod.
    One of the biggest issues in a W body is body/weight transfer.
  9. #9 Re: New car first time going to the track
    Apr 2011
    Vassar, Mi
    Cable mod cost $8 and netted me .3 off my ET back when I was slower
    Quote Originally Posted by JoRoW99 View Post
    If your coming off the convertor at 2K and getting it to hook I need to know your magic spell because ive got MT ET's and cables and I cant get a clean 60' anywhere higher than 1200-1400rpm even at norwalk.
  10. #10 Re: New car first time going to the track
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    how much did the hp tuner cost you?
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  11. #11 Re: New car first time going to the track
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Quote Originally Posted by evand View Post
    Yeah don't go through the water box street tires. It drags water on to the track and everyone hates you. Also I like having it in 3 so it doesn't bang into 4th when you let off the gas after the stripe.
    97 Bonneville SE Not so much a 97 anymore
  12. #12 Re: New car first time going to the track
    Jun 2013
    United States
    I will take a look at the back suspension. I don't want anything ghetto rigged.
    I would consider a strap or cable but something build for the proper use. Maybe adjustable holes so the tension can be relieved mostly for normal driving.
    like this Competition Engineering Part No. C2025 - Bump Stop Sets
    or possibly http://www.summitracing.com/parts/ex...Fcad4AodSRIAjg
  13. #13 Re: New car first time going to the track
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  14. #14 Re: New car first time going to the track
    Sometimes I don't quite understand the cable mod because no one will ever run that setup on the street, so its not a very useful 1/4 ET.
  15. #15 Re: New car first time going to the track
    Mar 2012
    Dallas
    why is it not useful at the track?
    its track only mod
  16. #16 Re: New car first time going to the track
    Texas
    So Evan when is your first trip to the dragstrip?
    85 Corvette
    01 TA
    03 Z06
  17. #17 Re: New car first time going to the track
    Apr 2011
    Vassar, Mi
    Thats like saying "I dont understand why people use slicks at the track, they dont even work on the street" or pulling the spare tire and headlight out, or using nitrous strictly for the track, or running race gas and a smaller pulley only at the track. Either way cables are a great track mod and if your bracket racing they make it easier to get consistent 60's. They take like 5 minutes to put on and cost less than $10
  18. #18 Re: New car first time going to the track
    Quote Originally Posted by Anthony Smith View Post
    I'm not arguing that the cable mod is not a good mod, but if you're going to race someone and you tell them you run a 12.x with slicks and race gas and no interior but you really run a 14.x in street trim, then what good is that 12.x time slip?
  19. #19 Re: New car first time going to the track
    Who cares, if it runs 12's...then it runs 12's.
    Not my fault you made it slow again by adding all the stock crap back on it.
    See what I'm getting at?
  20. #20 Re: New car first time going to the track
    No because something that runs 12's in track trim is going to get smoked in street trim by an LS1, on the street.
    I don't care how fast the drag cars that get hauled to the track are, because they cant drive it home.
  1. How much KR is okay? - It's track time!
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2010, 03:48 PM
  2. 1st time ever to a track....
    By bballa0740 in forum Track Sessions and Kills
    Last Post: 08-23-2010, 05:02 AM
  3. new track time!
    By 2000GTP in forum Off Topic Discussion
    Last Post: 11-22-2009, 12:23 AM
  4. Track Time
    By KawaFord in forum Track Sessions and Kills
    Last Post: 10-01-2009, 05:25 PM
  5. New track time
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 05-14-2009, 02:35 PM
