Thread: Even with Charger RT Daytona
Results 1 to 20 of 39
  1. #1 Even with Charger RT Daytona
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    I have a 2000 GP GT with a Gen3 top swap, XP cam, ported heads, 42 injectors, HAI, Headers. I went up against a Dodge charger RT Daytona edition on the freeway. We went at it twice from around 80 to 130 and stayed even the entire time on both runs. How did I do with 2.9lbs of boost and 18 degrees of timing? lol
  2. #2 Re: Even with Charger RT Daytona
    3 psi?
    lol.
    They're mid to low 14 second cars if it's the first gen...good run?
  3. #3 Re: Even with Charger RT Daytona
    antioch ill
    I got my ass handed to me by a rt once from a dig was not good
  4. #4 Re: Even with Charger RT Daytona
    Quote Originally Posted by Matt Palm View Post
    Modded?
    Need driver mod, lol.
  5. #5 Re: Even with Charger RT Daytona
    antioch ill
    Stock and does need stig mod
  6. #6 Re: Even with Charger RT Daytona
    May 2012
    Phoenix, AZ
    I also raced an Infiniti G37 sedan, the newer one. we went from about 50 to 80 and I was starting to pass him around 80 since I was behind him to start off. I was surprised to see how much get up they had.
  7. #7 Re: Even with Charger RT Daytona
    Again,
    3psi?
  8. #8 Re: Even with Charger RT Daytona
    May 2012
    Phoenix, AZ
    yes a whole whopping 3psi. Can't figure out whats going on.
  9. #9 Re: Even with Charger RT Daytona
    Vac leak?
    SES lights?
    Yeaaaa.
  10. #10 Re: Even with Charger RT Daytona
    May 2012
    Phoenix, AZ
    I had 2 codes from SES light. One was possible vac leak. Checked my gas cap, seal was beat up, so replaced that. other code was coolant temp too low. Changed the thermostat to 180 and that fixed the coolant temp. My vac lines are new, my buddy also sprayed carb cleaner on the vac lines trying to find a vac leak and nothing.
  11. #11 Re: Even with Charger RT Daytona
    May 2012
    Phoenix, AZ
    SES light stayed on for a while and about a week later it turned off
  12. #12 Re: Even with Charger RT Daytona
    3psi is still wrong.
    What is the code, P0171?
    Wheeeeeeeeeeeeeeeee
  13. #13 Re: Even with Charger RT Daytona
    May 2012
    Phoenix, AZ
    I know. Im not sure. I think I still have the codes but I dont have them on me. Ill check later. Could it be a bad belt tensioner? I've been getting a squeak the past couple of days and it seems to be coming from the tensioner. I put my hand on it while the car was idling and there was a lot of vibration.
  14. #14 Re: Even with Charger RT Daytona
    Do you have the belt routed correctly? lol.
  15. #15 Re: Even with Charger RT Daytona
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I Pooped all over an R/T Charger. 3.5 pulley, SSIC, SSAC, can ZZP Tune, heads. It sounded good until I passed it then all I could hear was my blower.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  16. #16 Re: Even with Charger RT Daytona
    May 2012
    Phoenix, AZ
    lol yes. I followed a diagram. Pathetic if it isn't
  17. #17 Re: Even with Charger RT Daytona
    BBV working?
    venting to atmosphere?
    I don't know...KR? Fuel trims?
    Maybe start a thread and see why your car isn't working right.
  18. #18 Re: Even with Charger RT Daytona
    May 2012
    Phoenix, AZ
    BBV is working. Rod is going all the way down when accelerated. I disconnected the top of BBV and capped the top of blower. nothing changed. Bottom of bbv is open to atmosphere. I scan with an aeroforce and no KR. I do have a thread about it and was given ideas. tried everything that was thrown at me. I posted my fuel trims and a guy said they look good.
    What I find weird is when I had it at the dyno shop I was putting out 7psi. I do have the L36 MAP, but the Dyno shop some how tuned around it. A week later I got an aeroforce. scanned it and it read 2.9psi and I did not feel a difference in power......
  19. #19 Re: Even with Charger RT Daytona
    oh boy, a "shop" tuned it.
  20. #20 Re: Even with Charger RT Daytona
    sounds like your tune is ***
    SMGPFC Member #10
  1. GTP VS SRT-8 Charger
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 10-13-2010, 12:22 PM
  2. Daytona Charger R/T
    By blueguy in forum Track Sessions and Kills
    Last Post: 04-17-2009, 01:36 PM
  3. GTP-vs-Charger Daytona/RT
    By mwalk00gtp in forum Track Sessions and Kills
    Last Post: 01-13-2009, 10:20 AM
  4. Cha cha cha charger!!
    By blackheart in forum Track Sessions and Kills
    Last Post: 12-18-2008, 10:14 PM
