Thread: track night need help
Results 1 to 8 of 8
  1. #1 track night need help
    SE Level Member Bino0527's Avatar
    Stockton ca
    whats up guys. just wanted to get your guys thoghts. went to the track last wen. ran13.7 @ 101 with a 2.2 60ft and .049 reaction time. my mod are 3.1 pully , pacesetters headers, zzpfull stack intercooler, s1x cam, 105 springs, hot air intake, 104al, toyo proxy street slicks 20 psi, is this normal for the mods i have 13.7 i had no traction all of the 60ft.i thaght i should be in the low 13 or even the high 12. some help would be welcome
  2. #2 Re: track night need help
    Needs better tune?
    Altitude?
  3. #3 Re: track night need help
    Omaha, NE
    What was the track temperature, barometric pressure and density altitude?
  4. #4 Re: track night need help
    Stockton ca
    oh ya i got a box tune from intence. the track was not preped very good. it was like 80 somthing and cooling that night.
  5. #5 Re: track night need help
    Stockton ca
    it was in sacramento ca.
  6. #6 Re: track night need help
    Omaha, NE
    You had drag radials and couldn't hook until past the 60ft... The throttle isn't an on/off switch. Practice launching and you will have a better ET your next time out.
  7. #7 Re: track night need help
    Stockton ca
    ok you think some kyb's will help to..
  8. #8 Re: track night need help
    Omaha, NE
    Spring blockers in the rear would help reduce suspension travel, and poly mounts all around would help get more torque to the ground.
    If you only run the drag radials at the track, you can prep them with any number of substances in different methods. I would advise doing your own research on that if that's something you're interested in.
    Instead of the intense tune, you should get HPTuners or have a local speed shop tune the car for you. Intense is in Ohio, so the density altitude and barometric pressures used for their tunes may not be accurate for where you are.
  1. track night round 2
    By Juanmiguel in forum Track Sessions and Kills
    Last Post: 11-28-2011, 11:14 AM
  2. track night videos
    Last Post: 07-21-2011, 04:14 PM
  3. Went to the track last night
    By glanzergtx in forum General Tech Discussion
    Last Post: 06-18-2011, 01:53 PM
  4. so I took it to the track last night...
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 05:55 PM
  5. Went to the track las night
    By TheOtherNick in forum Track Sessions and Kills
    Last Post: 08-09-2009, 04:33 PM
