Thread: dyno/tune vids 286whp 329wtq
Results 1 to 10 of 10
  1. #1 dyno/tune vids 286whp 329wtq
    SE Level Member jim97regalgs's Avatar
    May 2011
    boynton beach florida
    Ok this was done on a mustang dyno. Runs were done in 2nd gear. I put down 286whp 329wtq. 19*timing, low 11s afr, 11ps1
    i know the vids dont show much but she screams lol
    first vid was calibrating rpms and testing the straps. 2nd was my 286whp 329wtq pull.
    97 regal gs,L32 swap,vs cam,zzp fullsize ic,2.9,42.5lb,lq4 maf,zzp shift kit,zzp polly mounts,4" intake,SD headers,fp rewire,stage1vb,alt rewire,wrapped crossover pipe,160tstat,AL103's,3"exh,hp tuned.286whp 329tq(mustang dyno)12.6@110mph
    2012 Sonic 1.4 turbo 6mt
  2. #2 Re: dyno/tune vids 286whp 329wtq
    Omaha, NE
    Are the mods listed in your sig current?
    Quoting for reference:
    97 regal gs,L32 swap,vs cam,zzp fullsize ic,2.9mps,42.5lb inj,zzp polly mounts,custom 4" open cone intake,SD headers,fp rewire,stage1vb,alt rewire,wrapped crossover pipe,intense pcm,160 dr tstat,AL103's,3"mb exhaust,eibach springs,kyb struts,aem wide band,duel scanguages.
  3. #3 Re: dyno/tune vids 286whp 329wtq
    May 2011
    dyno slip pic
    Facebook
  4. #4 Re: dyno/tune vids 286whp 329wtq
    May 2011
    yes except now i have a zzp shift kit and lq4 maf
  5. #5 Re: dyno/tune vids 286whp 329wtq
    Omaha, NE
    I hope you don't take this the wrong way, but I think those numbers seem kind of low for your mods.
    This is from ZZPerformance via Which Cam Should I Buy? | | ZZP NewsZZP News : Most users dyno 300WHP with the VS cam and intercooler before tuning with stock timing. With tuning users are reporting back averages of 320-330WHP
    What octane gas are you using? Any known issues with the car?
  6. #6 Re: dyno/tune vids 286whp 329wtq
    May 2011
    yes well this was done on a mustang dyno wich always read low. i use this same dyno on all my cars and also use a dyno jet. and the difference between the is about 13%. so that would put me at your 320whp claim. 323whp 371wtq to be exact. mustang dynos have been called the heartbreaker. and for this very reason. running 93 octane.
  7. #7 Re: dyno/tune vids 286whp 329wtq
    mi
    They're just numbers. The strip is the real heartbreaker.
  8. #8 Re: dyno/tune vids 286whp 329wtq
    Banned
    CT
    Quote Originally Posted by jim97regalgs View Post
    This all depends on if the calibrations done beforehand are correct... in your case they seem right and your numbers look pretty respectable for your setup. The car likely runs very hard. Just tell people you make 280ish and let them scramble for excuses when their 350whp cars get smoked. Most people think inflating their whp numbers is impressive, I think the opposite is impressive
  9. #9 Re: dyno/tune vids 286whp 329wtq
    May 2011
    Quote Originally Posted by siLversLeigh View Post
    True that. Well the car is deff faster than when I ran a 13.2@107mph. Only diff is I now have a good tune, lq4 maf, zzp shift kit and no header leak.
    And ill be using my new set of nitto drags on modified 93 rx-7 fd rims wich only weigh 13.5lbs per rim. Should see some mid to low 12 sec passes.
  10. #10 Re: dyno/tune vids 286whp 329wtq
    May 2011
    Quote Originally Posted by SnowFlake View Post
    Could not agree more. But for posting on these forums I have to clarify these things. Lol
  1. dyno tune disaster
    By 707chance in forum Track Sessions and Kills
    Last Post: 07-12-2011, 01:05 PM
  2. dyno and tune shops
    By Tuned07GPGT in forum Introductions/Noob Questions
    Last Post: 08-23-2010, 12:05 AM
  3. New Dyno Tune Numbers
    By josh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2010, 04:27 PM
  4. anyone get a dyno tune from ZZP?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-17-2009, 04:53 PM
  5. My Dyno Tune
    By Keifer in forum General Tech Discussion
    Last Post: 07-15-2008, 07:12 AM
