Thread: dyno tune disaster
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: dyno tune disaster
    SE Level Member 707chance's Avatar
    Fredericksburg Va
    There is a folder in the HPTuners editor called Transmission Diagnostics where you can find a few parameters that restrict gear command. Our STOCK numbers are set at 5500 rpm and 62 mph. The rpm and mph must be UNDER these two parameters to enable gear control. MY current modified file on the car is set at 6200 rpm and 188 mph. Looking at my scan, the mph was at 145 mph, below the 188 requirement, and rpm was at 6050 which is under the 6200 rpm requirement which will allow gear command. This explains not only how it is possible to occur but why guys with stock trans tunes or just ratio changes cannot command a downshift when going over a certain speed.
    The TC used in my transmission package is not designed to be locked during WOT. The TC was locked during the dyno testing and could have been damaged. Debris could of then of been throw back into the transmission.
    2006 GXP almost done! I/H/C/E, TEPw/3.29s, small shot
  2. #22 Re: dyno tune disaster
    Stop me if I'm being a pain, because that's not the intention at all. RPM limiter wea removed?
  3. #23 Re: dyno tune disaster
    Fredericksburg Va
    the parameters were changed that allowed the car to be downshifted in manual mode...so I would have to say not remove but changed
  4. #24 Re: dyno tune disaster
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    wqhen doing a dyno run you want to have it in 3rd only, to do that you need to put the shifrt to the 3rd gear selection and then you start your pulls in lower rpms, and take your foot off right as the needle kisses redline....
    so far it almost sounds like its their fault to me...
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  5. #25 Re: dyno tune disaster
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Quote Originally Posted by iroc2 View Post
    ^ This.
    And not to sound blame happy, but the bottom line is: It was somebody's fault and because of that, your gonna have to come out of pocket. And let me give you a hint. That somebody is the tuner, or you. Oh and another hint: It wasn't you
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  6. #26 Re: dyno tune disaster
    Jul 2011
    Benton, AR
    I would talk to a lawyer at the very least. You need to make sure it is one that comes highly recommended. I'm telling you this because you need to make sure you do not get screwed. Would you want this to happen to someone else?
  7. #27 Re: dyno tune disaster
    Fredericksburg Va
    Attorney has been hired, paper work has been filed
  8. #28 Re: dyno tune disaster
    Jan 1970
    Maquoketa, Iowa
    Did you get the scan of the run? That would be very helpful, make sure you are positive it was that run as well, should see it.
  1. dyno and tune shops
    By Tuned07GPGT in forum Introductions/Noob Questions
    Last Post: 08-23-2010, 12:05 AM
  2. New Dyno Tune Numbers
    By josh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2010, 04:27 PM
  3. Dyno/tune day Northern Cali
    By TorqueAutoMotiv in forum West
    Last Post: 09-23-2009, 10:06 PM
  4. anyone get a dyno tune from ZZP?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-17-2009, 04:53 PM
  5. My Dyno Tune
    By Keifer in forum General Tech Discussion
    Last Post: 07-15-2008, 07:12 AM
