Thread: 2010 mustang gt
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 2010 mustang gt
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    I was running late for work doing 80, hit a light and made a u-turn, i thought it was an 05 gt with just an exhaust, he started reving at the light so i reved back thinking maybe i could get him off the line maybe itll be close, we went from about a 10 mph role (1st and 1st) he had a 5 speed, i had him til my car hit about 40 mph and he hit 3rd gear?
    So my question, whats it take for a gtp to beat a 2010 stang with an exhaust, and why the hell do gtps "Suck" in top end when they have 2.93s in them, and no my car isnt stock
  2. #2 Re: 2010 mustang gt
    Jersey
    i didn't have a problem beating a 05-07 gt, he ran a 15.xx
    16' wrx sti- stock
  3. #3 Re: 2010 mustang gt
    Because they dont make any power. Plus, the new '10 GT with exhaust and a good driver is a mid 13's car. Good luck.
  4. #4 Re: 2010 mustang gt
    Apr 2009
    stockton ca
    150 shot n2o / thread
  5. #5 Re: 2010 mustang gt
    Nov 2009
    centereach, NY
    sadly the driver was HORRIBLE, shifted slow and when i raced him from 60 to 100 i beat him and he claimed he couldnt get it into 4th gear.
  6. #6 Re: 2010 mustang gt
    GT Level Member josemolina2008's Avatar
    Modesto, Ca.
    5.0 in the 2011 those should be pretty quick.
    GP is gone...
  7. #7 Re: 2010 mustang gt
    Quote Originally Posted by josemolina2008 View Post
    Hardly. It is just a modular motor with a bigger bore.
  8. #8 Re: 2010 mustang gt
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    Hardly.....I agree with you 98% of the time but now 415hp is not something to **** with. Even the v6 base has moved up someone tested it out to run a 13.7. The base I'm talking about. So the gt and the v6 is no joke. The pony car is officially beating out the camaro/challenger crowd for 2011, and they better step up their game.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  9. #9 Re: 2010 mustang gt
    GT Level Member sic6's Avatar
    san marcos, tx
    Its a totally redesigned engine.It doesnt share any components like the older mod motors did since those are based on the truck engine to begin with.
  10. #10 Re: 2010 mustang gt
    So...if you change the cams/pistons/displacement/tuning it is a totally different motor?
    Ok.
  11. #11 Re: 2010 mustang gt
    Apr 2009
    stockton ca
    Its still a modular engine just has a larger displacment no biggie
    I just dont see the hype over the new mustang yea its got a few more ponies
    and in a couple years dodge will have advances with the challenger and then gm will boost up the maro its a game they play
  12. #12 Re: 2010 mustang gt
    Nov 2009
    centereach, NY
    Well i love pontiac and GM and all, but come on 240 hp with a s/c engine, the 2000 acura TL has 240 and its a 3.2, and than they get rid of the GTP and bring back no no im sorry steal the holden body and put a 5.7 in it that runs a 13.9 and weighs 3900 pounds? and people wonder why GM went under
  13. #13 Re: 2010 mustang gt
    Modesto, Ca.
    Ok.
    Actually they changed more than that they redesigned some other parts to make it flow more air and it uses another engine the so called "Coyote"
    GP is gone...
  14. #14 Re: 2010 mustang gt
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Ok.
    You keep arguing this, and I cannot understand why. Your argument is that it is a modular, so it is the same. That is like saying your 3.8L is just a modified version of the Ford 5.0L because they are both push-rod engines. The 2010 Coyote 5.0L is a whole new engine; get over it.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  15. #15 Re: 2010 mustang gt
    Quote Originally Posted by backinblackgtp View Post
    The 3800 S/C is from 1996 when are those other engines from?
    http://en.wikipedia.org/wiki/Ford_Mo....C2.A0L_Coyote
    Doesnt seem that much different, just some minor mods, not a whole new engine.
    Consider the BMW straight six has been redesigned a million times yet its still considered the same engine.
    New heads don't mean new short block design.
  16. #16 Re: 2010 mustang gt
    Waynesboro, PA
    Ford Modular engine - Wikipedia, the free encyclopedia
    You kids need to step back from wiki once in awhile. It is a great resource, but not the only place you should look. Try folks that have actually gone through-and-through the engine:
    2011 Ford Mustang GT 5.0 Coyote Engine - 5.0 Mustang & Fast Fords
    2011 Mustang GT 5.0L Coyote, in depth look - LRS Blog - Read Here Shop Here
  17. #17 Re: 2010 mustang gt
    Quote Originally Posted by JoshMcMadMac View Post
    From one of your links: "The new 5.0 really is an all-new engine sharing virtually no parts with the prior 4.6-liter. Only the bore spacing and deck height were carried over, allowing the block and heads to be machined on the same transfer lines with less re-tooling."
    ******* wiki.
    "headers" out of the box is nice.
  18. #18 Re: 2010 mustang gt
    Nov 2009
    centereach, NY
    i have faith in GM, they will produce the henesey camaro which will outbeat even fords supersnake. atleast i hope.... but than they have to work on the price
  19. #19 Re: 2010 mustang gt
    GM doesn't make the Hennessey Camaro...Hennessey does.
  20. #20 Re: 2010 mustang gt
    san marcos, tx
    The engine has been redesigned from the ground up to handle the potential power increases.
  1. It's 2010, let's move on...........
    By Purple Plazma in forum The Rant Forum
    Last Post: 01-16-2010, 06:19 PM
  2. Replies: 3
    Last Post: 01-13-2010, 10:54 AM
  3. 2010 SHO 12 sec 1/4
    By J GTP in forum Off Topic Discussion
    Last Post: 10-14-2009, 12:00 PM
  4. The Last Pontiacs 2010
    By GrandPrixGT00 in forum Off Topic Discussion
    Last Post: 10-09-2009, 01:55 PM
  5. 2010 Taurus SHO...
    By SlowM90 in forum Off Topic Discussion
    Last Post: 08-11-2009, 10:17 AM
