Thread: Went to the track (video)
Results 41 to 60 of 65
  1. #41 Re: Went to the track (video)
    Donating Users blowfishRus6's Avatar
    g.a.
    ugly, haha.
    i was wondering about the coolent lines. i kinda liked the idea of them on the driver side, seems like you would run into issuies with them on the passenger side hitting the belts
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #42 Re: Went to the track (video)
    Charles City, IA
    I think he meant diver's side since he said they would be easier to keep away from the belts.
    SMGPFC Two Nipple General
  3. #43 Re: Went to the track (video)
    g.a.
    i see. yea i like that set up better
    its slow.
  4. #44 Re: Went to the track (video)
    Charles City, IA
    Yeah my supercharge belt all ready ate my coolant overflow hose once.
  5. #45 Re: Went to the track (video)
    g.a.
    yea id rather not take the risk. have plenty of room on the other side.
    its slow.
  6. #46 Re: Went to the track (video)
    Once? I wish I was that lucky...try 4 times.
  7. #47 Re: Went to the track (video)
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Wow, you guys really need to reassess what you are doing with your intercooler lines. Mine are routed just fine with no chance of them getting chewed up.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  8. #48 Re: Went to the track (video)
    g.a.
    well if i had some i would reassess....
    ive heard issuies with it before so why not just send them out the other side???
    its slow.
  9. #49 Re: Went to the track (video)
    Portland Oregon
    I've seen some GTP's with good track prep get into 1.9 60's on regular street radials. I routinely do a 2.0X to a 2.1x 60ft depending on conditions with Bridgestone RE960's. If you can get your launch down I'd be willing to bet you could have a screamin run. Every tenth in the 60' you can take off is a lot on the e/t you can shave.
  10. #50 Re: Went to the track (video)
    Waynesboro, PA
    Quote Originally Posted by OH4CompG View Post
    1/10 in the 60' is roughly 2/10 in the quarter. I managed a 2.15 with cheap tires, and there is more there to be had. A good launch should easily be in the 2.0X region.
  11. #51 Re: Went to the track (video)
    Charles City, IA
    Quote Originally Posted by JoshMcMadMac View Post
    It was my overflow tank line that got ate up. It was in the factory location with factory tab holding it. It must have came loose or something. I zip tied it out of the way now.
  12. #52 Re: Went to the track (video)
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Quote Originally Posted by 00obgtp View Post
    I was also at the track sat nite and I made a 15.1 pass 1/4mile and 9.7 in the 8th with a 2.1 60 foot... and my mods are just intake, 180 Tstat and maintaince all done to the car and the rest bone stock so im hoping to go for low 13's or 12's when i put the mods in... so you must be having some kind of problems with your mods...
    you should have posted on the forums you where going for sure then i would have flagged you down.
    but theres always next time
  13. #53 Re: Went to the track (video)
    Oxon Hill, MD
    Man, I ran a 9.451 @ 73 in the 1/8 with a 2.097 60'. Where are you located? Good track prep or what? Just trying to wrap my mind around that time. I wouldn't think my NA 3800 is that much faster.
  14. #54 Re: Went to the track (video)
    g.a.
    hes top swaped with no tune, its probably knocking like hell
    its slow.
  15. #55 Re: Went to the track (video)
    Waynesboro, PA
    Quote Originally Posted by whitelightnin04MC View Post
    If he mustered the same 60' as you he would have been faster than you...although still slow for what it is. A tune can take care of that.
  16. #56 Re: Went to the track (video)
    Banned - Busted For Scamming
    Feb 2009
    Well technically not top swapped, but in a sense yes. My car is a GTP but i have an l36 block, so high compression. I know i need a tune but yea if i had a better 60 foot time it would have been better. Im gonna get back to the track soon after i reinstall my 3.4 pulley, water meth, and 1.9 rockers.
  17. #57 Re: Went to the track (video)
    Waynesboro, PA
    Tune before you go balls-out anymore. Unless you like motor swaps.
  18. #58 Re: Went to the track (video)
    Hmmm...maybe try and install your water meth on the pulley you have now if you were pulling times like you did.
  19. #59 Re: Went to the track (video)
    Feb 2009
    Is there a way where i could watch my obd2 scanner plugged in while driving to calculate kr? It shows timing degrees and was just wondering as i dont have money to buy a scan gauge right now.
  20. #60 Re: Went to the track (video)
    g.a.
    does it read while the car is runnin?? if so get someone to ride shotgun and watch it while you flog it.
    its slow.
  1. took the GP to the track
    By UWISHU1 in forum Off Topic Discussion
    Last Post: 09-29-2009, 08:20 AM
  2. Track ???
    By GTP4 in forum Track Sessions and Kills
    Last Post: 10-02-2008, 08:42 AM
  3. well...so much for the track
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-30-2008, 03:52 AM
  4. So I went to the track right?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 04-05-2008, 11:57 AM
  5. F***** VHT at the track
    By TDCRacing in forum The Rant Forum
    Last Post: 04-01-2008, 11:28 AM
