Thread: Handling in the snow
Results 1 to 15 of 15
  1. #1 Handling in the snow
    Chicago, IL
    So I was wondering does the car handle in the snow based on the tires alone or is there other things I can do/check/upgrade to get better handling?
    MSD Ignition Coils, K&N CAI, SLP Headers/Downpipe/High Flo Cat/Cat Back Exhaust, Overkill PCM, 20" Moda Rims
  2. #2 Re: Handling in the snow
    I live here. UR LOSN's Avatar
    Rockford, IL
    I have Winter X-ice snow tires on the front of my 2000 GTP. I think it does QUITE WELL!
    I am able to swing the rear of the car out with the flip of the wrist.... or go through tons of snow.
    My opinion.... it is all in the tires.
  3. #3 Re: Handling in the snow
    tires help a lot, but these cars understeer like crazy in the snow as it is.
  4. #4 Re: Handling in the snow
    Chicago, IL
    The reason I ask is because I get horrible traction in the snow. I'm guessing its the tires but was hoping it wasn't.
  5. #5 Re: Handling in the snow
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I try to lose traction all the time.
    Im an Ebrake Fiend!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  6. #6 Re: Handling in the snow
    i cant start from a dead stop without spinning my tires a little. i just turn the traction control off and have at it.
  7. #7 Re: Handling in the snow
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by Freebeer187 View Post
    Im an Ebrake Fiend!
    x2 it's the only thing that keeps me entertained when I'm forced to go slow .
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  8. #8 Re: Handling in the snow
    Jan 1970
    Maquoketa, Iowa
    Usually if I just turn t/c off and drop it in second and nudge my way out and it works... Sometimes you just dig yourself in if you floor it without any momentum. If I cant nudge my way out, I start going back and forth until I break free.
    These cars can get the front wheels to spin pretty good on dry pavement, so just learn to ease into or blip the throttle and ease back steadily when you feel the tires break loose.
  9. #9 Re: Handling in the snow
    Chicago, IL
    Yeah turning off the T/C does seem to help. Other then the snow the traction is really good.
  10. #10 Re: Handling in the snow
    SE Level Member Mikefisher's Avatar
    Winkler,Manitoba,Canada
    For me I dont seem to have a problem at all getting grip and I have some ****!y tires on.I guess you guy just have heavy foots!!! j/k I think that the deep deep frezze that we are having helps getting grip to.The warmer weather does get a little bit more slick.
    Pike---- Family of rapacious,malevolent,razor-toothed freshwater game fish that will strike instantly and violenty at just about any lure you decide not to try...
    http://s43.photobucket.com/albums/e381/mikefisher99/
  11. #11 Re: Handling in the snow
    100mph stoplight starts FTW
  12. #12 Re: Handling in the snow
    Nov 2008
    wall lake iowa
    i have never done that lol
    and e braking is FUNNNN
  13. #13 Re: Handling in the snow
    SE Level Member mjmusicpro's Avatar
    Jan 2009
    Iowa
    The 2008 GXP is the worst handling vehicle I've ever driven in the snow. Even with front wheel drive the extra wide tires recommended for the car are horrible. I actually bought new all season Eagles shortly after purchasing the vehicle, but still get horrible traction. I threw 4 sandbags in the trunk which seemed to stabilize the vehicle overall, but this is still one better left in the garage in bad weather. With the standard front wheels of 18" X 8" and rear wheels of 18" X 7", and a recommended tire size of 255-45-18 front and 225-50-18 on the rear, I'd have a better chance of floating on water then getting traction in the snow. I tried to downsize my wheels and tires to something narrower, but couldn't come up with anything with the same wheel diameter. With the computerization I think I'd be alright as long the finished tire heighth was the same. I would sure take any tips or advice on where to go from here.
  14. #14 Re: Handling in the snow
    Aug 2008
    Long Island, New York
    if you want to keep your same size wheels you should probably get Blizzaks... they are supposed to be really good tires for driving in the snow
  15. #15 Re: Handling in the snow
    Nov 2008
    Cedar Rapids, IA
    ^^ x2 I had a full set of blizzkas on my old Jetta and they were phenomenal!!
  1. Post pictures of your car in the snow!
    By domesticdriver in forum Off Topic Discussion
    Last Post: 03-08-2009, 06:40 PM
  2. Snow
    By UR LOSN in forum The Rant Forum
    Last Post: 12-29-2008, 01:23 PM
  3. yes there is snow!
    By Mikefisher in forum Off Topic Discussion
    Last Post: 11-12-2008, 09:57 PM
  4. A closer look at a snow flake
    Last Post: 07-16-2008, 12:22 PM
  5. GMPP handling kit
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 05-03-2008, 10:50 PM
