Thread: Will Steel Wheels from a 2000 Dodge Caravan fit on a 2002 Grand Prix?
Results 1 to 5 of 5
  1. #1 Will Steel Wheels from a 2000 Dodge Caravan fit on a 2002 Grand Prix?
    Jan 2015
    Michigan
    I believe the Caravan wheels are 5 X 114 and I believe the tires are 215/65/15 or possibly 215/65/16?
    The minivan is broke down in the garage and the tires are in really good shape. If they fit on the Grand Prix I may through them on just to get me through the winter.
  2. #2 Re: Will Steel Wheels from a 2000 Dodge Caravan fit on a 2002 Grand Prix?
    Won't fit, you need 5x115's.
    And the hub bore is likely not even close to the same.
    Dismount the tires if they are 215/65/16 and put them on your car.
  3. #3 Re: Will Steel Wheels from a 2000 Dodge Caravan fit on a 2002 Grand Prix?
    Jan 2015
    Michigan
    thanks
  4. #4 Re: Will Steel Wheels from a 2000 Dodge Caravan fit on a 2002 Grand Prix?
    hangover park IL
    they should fit
    the dodge and the GM wheel bearinhgs are identical except for the rotor pilot dia (same spline, same 3 bolt pattern, same threads), the wheel/hub pilot dia is identical. dont worry about the 5x115 vs 5 x 114,3 bolt pattern stuff...its a moot point.
    ive seen jeep wheels on the C body's and from the fitments id say your fine
    ~James~ Psychotic Gearhead
  5. #5 Re: Will Steel Wheels from a 2000 Dodge Caravan fit on a 2002 Grand Prix?
    hangover park IL
    for posterity's sake i had to do wheel bearings on my 98 intrepid and i had a spare GM hub laying on the bench.
    1st gen crosslaces fit on the dodge, dont see why you couldnt put the dodge(or ford) 5x4.5 wheels on a GM
    if they are 15" and youve upgraded your brakes youll have brake clearance issues
  1. 2002 Grand Prix GTP - Uograde Wheels to a 17" 40th anniversary Edition Wheels
    By phogstenjr in forum Introductions/Noob Questions
    Last Post: 01-10-2015, 03:02 PM
  2. 2002 Pontiac Grand Prix Rims and Wheels for sale
    By smitz327 in forum For Sale - Parts
    Last Post: 12-28-2013, 03:54 PM
  3. 2012 Dodge Grand Caravan is quick
    By tod1d in forum Off Topic Discussion
    Last Post: 01-31-2012, 12:36 AM
  4. need info on 2002 mustang vs 2000 grand prix gt
    By bloxmagic in forum Track Sessions and Kills
    Last Post: 07-09-2009, 05:12 PM
