Thread: Gorilla lug nuts and Key??
Results 1 to 16 of 16
  1. #1 Gorilla lug nuts and Key??
    Nov 2012
    Madison
    How many of you guys have used these?
    I just got mine today with the key,.. and jesus almighty is the key thin walled.
    I don't even want to start dicking with them if these socket keys crack as easy as some of the reviews read.
    Hell, I'll just use the old nuts, tape up the socket to avoid scratches and send the Gorilla set back.
    I would like to use the Gorillas since I have them but don't need the paranoia. Spare key socket and 4-way wrench seems to be a must.
    I need a yea or nay.
  2. #2 Re: Gorilla lug nuts and Key??
    SWPA
    Is it the splined ones? I think mine may have been Gorilla and my socket cracked when I had a flat on the side of the road. The lug nuts also had surface rust all over them and looked like sh!t.
    I ditched mine right after the socket cracked. I got some Dorman replacement acorn lug nuts.
  3. #3 Gorilla lug nuts and Key??
    I just stick with the hex style lugs.. That way I don't scratch the rims up when removing or putting on the rims and it's a standard hex so replacement is easy
    04 Comp G.
  4. #4 Re: Gorilla lug nuts and Key??
    Nov 2012
    Madison
    Cool, that's what I was afraid of.
    Sending them back rightthehellNow!!
  5. #5 Re: Gorilla lug nuts and Key??
    I have two sets of McGard lugs. One in chrome and one in black. They never rust, tarnish or anything. I airgun them on and off constantly. I hate locking lugs..
  6. #6 Re: Gorilla lug nuts and Key??
    Dec 2010
    ATL,Georgia
    I've got Gorilla lock lugs and they are great... what's the problem? I've also ripped them with the impact plenty of times lol
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  7. #7 Re: Gorilla lug nuts and Key??
    Kansas
    I got these, and had it has a thin walled socket. I have never had a single problem applying or removing via pneumatic power even though they say not to. Lug nuts are still in great shape with no chips or rust.
    http://www.ebay.com/itm/Black-Spline...item20d39c484a
    That seller also has hex acorn sockets as well.
  8. #8 Re: Gorilla lug nuts and Key??
    Nov 2012
    Madison
    Quote Originally Posted by NegativeOne13 View Post
    Looks to be the splined ones I bought except chrome. I am worried that the socket is to thin and might crack/tear out when I wrench with a breaker. I don't want the hassle of extra keys for insurance and a 4-way lug wrench for even torque.
    I bought them because my new TSW wheels have a smaller opening than the OEM wheels and wanted to avoid any scrapes. On a trial run I just used clear packing tape around my 19mm deepwell and it worked OK with the old stock lugs.
    The reviews on that thinwall key are for the most part not stellar.
  9. #9 Re: Gorilla lug nuts and Key??
    spline drive lugs suck because eventually you'll round one off, which breaks both the lug and they key. i am highly against them.
    if you're looking for a set that you don't have to worry about scuffing the wheels and still are being cheap you want to look for a set with an internal hex key, like these:
    http://www.amazon.com/Amico-Locking-...2x1.5+lug+nuts
    although they are open ended, they work flawlessly. i used them on my subaru for a long time. DON'T get a set with a star key, get a set with a hex key.
    or get some like these and be careful:
    http://www.amazon.com/M12X1-5MM-ALUM...2x1.5+lug+nuts
    my 2 cents here, from a wheel geek.
  10. #10 Re: Gorilla lug nuts and Key??
    Bio, have you tried a "colored" set of those internal hex key ones? Does the finish chip off within a wheel removal or two? Those looks interesting (the Amico ones).
  11. #11 Re: Gorilla lug nuts and Key??
    Jan 2009
    Tallahassee, FL
    I have a set of chrome Gorilla lugs that I've ha for years and they still look great. The chrome hasn't peeled and I haven't had any problems with the socket. I did run some colored ones briefly and the color did chip off.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  12. #12 Re: Gorilla lug nuts and Key??
    Nov 2012
    Madison
    Those Amicos looked pretty good but most were 16 lugs packages.
    I said screw it,my stockers are actually in good shape. Quite the surprise since the torque stars have lost a good chunk of the chrome plate.
    If I do purchase some down the road I'll do the McGards.
    But the solution for the on and off will be tape.
  13. #13 Re: Gorilla lug nuts and Key??
    Quote Originally Posted by Damnir View Post
    i had a set of black ones and they chipped around the base pretty much immediately, but the rest of it stayed pretty good. i only ran them for a season, though.
    otherwise i have put tape on around one of my sockets to make sure i didn't scratch the wheel.
  14. #14 Re: Gorilla lug nuts and Key??
    Nov 2012
    Madison
    Well I thought I would try some of the hex socket lugs, ordered them yesterday.
    I'm hoping the neon chrome isn't to rainbowie...If dudes start winkin at me I'll know.
    sumbiitch, I couldn't find good ol chrome
  15. #15 Re: Gorilla lug nuts and Key??
    I'm sure they'll look nice! Judging by the picture, I would assume about half of that lug will be exposed?? Have a link where you bought these? I have been looking for a set if the "right" set came along since it's just a cosmetic upgrade!
  16. #16 Re: Gorilla lug nuts and Key??
    Nov 2012
    Madison
  1. Lug nuts
    By A70Runner in forum General Tech Discussion
    Last Post: 01-08-2012, 10:46 PM
  2. Lug Nuts?
    By Confusingboat in forum Tires & Wheels
    Last Post: 06-06-2011, 11:52 PM
  3. GP going nuts
    By DDPeppa in forum General Tech Discussion
    Last Post: 09-14-2010, 06:36 PM
  4. 06 GXP Lug Nuts
    By wdb in forum Shops and Community Heroes
    Last Post: 05-05-2010, 02:27 PM
  5. PE nuts
    By Sabrewings in forum PCM Tuning
    Last Post: 07-16-2008, 05:33 PM
