Thread: can I run a 205 tire?
Results 1 to 12 of 12
  1. #1 can I run a 205 tire?
    SE Level Member powerranger262's Avatar
    Nov 2009
    I picked up a set of snow tires for free. They are new and the previous owner just wanted them out of thier garage. Question is, could I run these on my wife's grand prix. It's a 2004 grand prix gt. The size on there now is 225/60/16. These are 205/60/16. It's about an inch shorter in height, and just under an inch shorter in width.
    She's due for new tires, but I thought that if I could, I would use these for this winter and then get new tires in spring.
    2004 Grand Prix GT 3.8L
  2. #2 Re: can I run a 205 tire?
    Same rim size...
    Same sidewall height...
    tire is just 20mm skinnier...
    would it work?
    Sure.
    I wouldn't stretch a tire ever anyways...but that's me.
  3. #3 Re: can I run a 205 tire?
    It'll look funny and your speedo will be pretty far off, but you could still run them.
  4. #4 Re: can I run a 205 tire?
    Sidewall wouldn't be the same height nick. They'd be off some. I'd just get a different set of rims to run them on and swap when needed.
  5. #5 Re: can I run a 205 tire?
    Nov 2009
    Stocks are 26.6x8.86 and the new tires are 25.7x8.07.
    How wide are the stock rims?
  6. #6 Re: can I run a 205 tire?
    16x6.5
  7. #7 Re: can I run a 205 tire?
    SWPA
    1" shorter and 3/4" narrower. I wouldn't do it.
  8. #8 Re: can I run a 205 tire?
    given it was right right sidewall height, i'd run it. 205 on a 6.5" wide wheel is easy as pie. and it'll go through snow well with that skinny tire.
  9. #9 Re: can I run a 205 tire?
    I'm running 205/70 on my van from a gp and that thing eats snow
  10. #10 Re: can I run a 205 tire?
    SWPA
    Its NOT the right sidewall height.
    225/60 has a 135mm sidewall
    205/60 has a 123mm sidwall
    That's a difference of 24mm overall
  11. #11 Re: can I run a 205 tire?
    i didn't say it was. context clues.
    i'm actually referring to it as not the right sidewall height.
  12. #12 Re: can I run a 205 tire?
    Oct 2013
    Alaska
    I live in Alaska and run that exact tire on spare rims and it performs perfectly in the Winter and much better then 225. The speedo is off but that is no big deal.
  1. Flat tire sound, but no flat tire?
    By biggd1980 in forum 04+ Specifics
    Last Post: 09-14-2013, 04:43 PM
  2. Bad tire?
    By mattstansbury in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2013, 11:30 PM
  3. 265 tire?
    By Lishap in forum Tires & Wheels
    Last Post: 11-21-2012, 03:45 PM
  4. Old tire fun
    By EJOUIE in forum Off Topic Discussion
    Last Post: 04-08-2010, 11:03 PM
  5. tire rack ? about this tire
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 03-09-2009, 09:12 PM
