Thread: Steel Rims Help?
Results 1 to 9 of 9
  1. #1 Steel Rims Help?
    Jun 2013
    Canada
    Hey guys I just bought these 215/60/16 toyo winter tires and I need rims so I am just gonna go cheap and get steel rims and I was wondering if these are the right rims to get/bolt pattern!
    16 Inch steel rims East Regina, Regina
  2. #2 Re: Steel Rims Help?
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    It will fit you shouldn't have problems , tecnally you need 5x115 but some people will argue that 5x114.3 is 5x115
    2004 Grand Prix GTP 150,000 " The New Edition "
  3. #3 Re: Steel Rims Help?
    Jun 2013
    Canada
    Well is there a major difference like .7 off it has to be 115 not?
  4. #4 Re: Steel Rims Help?
    Oct 2012
    Philadelphia
    To me personally no, but people argue that you can snap your lugs running that offset but I think it's just hype.. I'm running 5x114.3 with no problem and I drive hard
  5. #5 Re: Steel Rims Help?
    Oct 2012
    Philadelphia
    If your gonna get steel rims why not just go to the junk yard pull some rims & get the right bolt pattern?
  6. #6 Re: Steel Rims Help?
    Jun 2013
    Canada
    I don't think they will have any but ill Have to talk to my dad.!
  7. #7 Re: Steel Rims Help?
    Jun 2013
    Canada
    My dad said they would work but ill double check on this
  8. #8 Re: Steel Rims Help?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    That's kinda expensive for some steel rims. I found 4 GP rims I plan on using for winter rims locally for $100. Look better and are guaranteed to fit.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  9. #9 Re: Steel Rims Help?
    like said up there, thats a bit much for steel wheels and not even tires. i got my sts wheels for 250 with tires.
    hit a JY or keep looking on line for a better price. i would.
  1. Stainless steel hoses need help
    By smyoung52 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2013, 08:22 PM
  2. My new perforated stainless steel grills
    By FuglyGTP in forum Visual/Body Modifications
    Last Post: 08-27-2010, 10:44 PM
  3. My steel wheel design :D
    By nawarkk in forum Off Topic Discussion
    Last Post: 03-25-2010, 07:41 AM
  4. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
