Thread: Preview to my new setup
Results 1 to 20 of 27
  1. #1 Preview to my new setup
    GT Level Member carcrobatics's Avatar
    Dec 2012
    California
    It's bout to get real stupid
    5x115 to 5x120 30mm thick
    wheel is 16x8 ~+62 offset
    questions comments welcome
    '00 GT - Build Thread: XXX - SOLD
    '93 Miata - Drift Project
  2. #2 Re: Preview to my new setup
    You've got an F-Body/Vette bolt pattern now.
    Go get better wheels.
    Naaaaow.
  3. #3 Re: Preview to my new setup
    How thick is that spacer?
  4. #4 Re: Preview to my new setup
    Dec 2012
    California
    30 millimeters thick
  5. #5 Re: Preview to my new setup
    Dec 2012
    California
    Quote Originally Posted by blueguy View Post
    Naaaaow.
    I would but I just got a full new set of tires that's not gonna go to waste. More time to find the perfect set though!
  6. #6 Re: Preview to my new setup
    What a set of those set you back and where did you get them?
  7. #7 Re: Preview to my new setup
    Dec 2012
    California
    Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
    305 flat, very very high quality stuff here.
  8. #8 Re: Preview to my new setup
    ...have fun trying to fit a wheel with okay specs now that you've got an automatic 30mm more offset.
  9. #9 Re: Preview to my new setup
    Dec 2012
    California
    I don't plan on it honestly. But there are wheels out there to suit every situation.
  10. #10 Re: Preview to my new setup
    Jun 2013
    Metro Detroit
    Isn't there an adapter plate that is less than 30mm??
  11. #11 Re: Preview to my new setup
    Quote Originally Posted by 92builtbird View Post
    i think you can get adapters in as little as 15mm thick, but the issue with that is you'd have to trim down the stock wheel studs. 25mm or more allows you to not have to do that in most cases.
  12. #12 Re: Preview to my new setup
    Dec 2012
    California
    This is correct, though there are pockets in-between the stud holes on my wheels that allow the studs some clearance before touching the wheel so I wouldn't really have that problem.
  13. #13 Re: Preview to my new setup
    Dec 2012
    California
    Everything is on officially, one wheel needs to be repainted due to clearcoat peeling. Just need to figure out where I can get a paint match for Pontiac's silver wheels.
    Also, I'll be ordering coilovers next weekend because I have a one finger gap in the back and two in the front, not on my watch!
    There will be more pics in my build thread tomorrow at different angles if anyone cares.
  14. #14 Re: Preview to my new setup
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Love it!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  15. #15 Re: Preview to my new setup
  16. #16 Re: Preview to my new setup
    Jun 2013
    Metro Detroit
    I guess I don't see the point.
    Why not run an 8.5" wheel with a 30 or 36mm offset?
  17. #17 Re: Preview to my new setup
    Because: moar poke + fbody wheels?
  18. #18 Re: Preview to my new setup
    Jun 2013
    Metro Detroit
    Or you could run virtually any 114.3 wheel that you want.
    I'm not hating, just unsure of the point, especially when you're already not flush with an 8" wheel. Basically handicapped yourself into running >8" wheel
    Like this guy said: ...have fun trying to fit a wheel with okay specs now that you've got an automatic 30mm more offset
    Clean car though!
  19. #19 Re: Preview to my new setup
    Dec 2012
    California
    Clean car though!
    Well I'll eventually upgrade to the WS6 Trans Am wheels that are 17x9 with the same offset of the wheels I have now, then I'll be able to run a summer tire on those. I really like the style of these wheels because I feel they match the car pretty well also. I don't feel like buying new wheels for this car anymore, I'm just about done with it.
  20. #20 Re: Preview to my new setup
    Jun 2013
    Metro Detroit
    Quote Originally Posted by carcrobatics View Post
    If you run those wheels with the same offset, you'll be sticking out yet another inch.
  1. my setup
    By shawnschuldt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 03:14 PM
  2. New HID and LED setup.
    By Koniig in forum Visual/Body Modifications
    Last Post: 09-17-2010, 12:16 AM
  3. GPF.net Community ScreenSaver Preview
    Last Post: 09-02-2008, 12:56 PM
  4. Remember that Video Preview? It's done
    Last Post: 08-24-2008, 07:31 PM
  5. Preview Of Things To Come Later Today
    Last Post: 06-26-2008, 07:45 PM
