Thread: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
Results 1 to 9 of 9
  1. #1 2004+ 18" wheels with ssc springs. What size tre and offset rim?
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    Title pretty much says it all. I'm going to move away from the engine modding for now and just go for looks.
    I have a 06 GT and was wondering what offset the rims can be and what tires will fit without looking like a rubber band , and will not rub when turning. Thinking 245/45/18?
    I am looking at the SSC springs unless anyone has better options. Vogtland would be my second choice.
  2. #2 Re: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
    Nov 2012
    MN
    Oh and as far as the kyb struts, what is the best option , as most people I see on lowered cars seem to run that brand the most. Also wondering about
    Anti pogo washers
    Top hats
    Mounts
    And anything else I may need.
    I did go through the sticky on lowering but am just looking for a little updated info. Thanks
  3. #3 Re: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    I run 245/45 18s on my '02. I just switched from KYB gr2s to the agx's. Its like night and day with my ssc springs. partsgeek.com has a set of agx's for around 440 shipped.
  4. #4 Re: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
    Nov 2012
    MN
    Thanks man I was wondering about the comparison between the 2. I probably should have put this in the suspension section as its more of that topic.
    I know the pattern is 5x115 , but the offset confused me. In the sticky above it said stock tires were a 52 offset. But when using "up to " an 8.5 inch wide rim you can change the offest to 38-48 I believe it was.
    Now I would like a wider looking stance , so does the lower offset# just push the tires out a little more?
  5. #5 Re: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
    Nov 2012
    MN
    Just trying to basically find out what wheel width and offset I need , to go with what 18" tire size. So I can start looking
  6. #6 Re: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
  7. #7 Re: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
    Nov 2012
    MN
    Thank u sir
  8. #8 Re: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
    Nov 2012
    MN
    After doing some reading I think the vogtland springs seem like a better choice for me. Better ride and not having to worry about the CV vibration as much is a big plus. I know they don't make them anymore for 04+ grand Prix, but I'm wondering what is a good price for them. This is one site I came across
    Chevrolet Impala SS Vogtland Lowering Springs [959220] - $213.99 : Swift Motorsports, Import Performance Starts Here
  9. #9 Re: 2004+ 18" wheels with ssc springs. What size tre and offset rim?
    You can fix any axle vibrations with 20 bucks, its just a spacer for the motor mount. Install them while doing the springs.
    I waited till after I did a drop on SSC springs, still only took an hour.
    They say the drop on those springs you posted is 1.4in, I bet you wont even get 1in of drop.
  1. What tire size do you run on 18" wheels?
    By Jochen in forum Tires & Wheels
    Last Post: 03-13-2015, 11:53 PM
  2. raising offset on my wheels....yes or no?
    By twol8uluz in forum Tires & Wheels
    Last Post: 03-30-2012, 07:02 PM
