How much trouble w/ rubbing will I run into?
my 8.5" wide wheels rubbed a bit, yours are 1" less, you will be fine
That's a good amount of poke
You have 24mm offset tod? Do you have any pics?
24mm offset isn't that big of a deal on a 7.5" wide wheel. it should fit fine.
Thanks for writing bio. These wheels that I'm looking at have tires on them. Is there a certain size I need to stay under?
245/45/R18 is what most of us would run on an 18. stick around that size, just move around the widths and keep the sidewall the same height.
Forum Rules
