Thread: Will 255/45-18 wheels rub on dna drop springs? Wheel experts need advice!
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Will 255/45-18 wheels rub on dna drop springs?
    GTP Level Member buickman104's Avatar
    NYC
    Quote Originally Posted by oldsman105 View Post
    BAHHAHAHAHAHAHHAHAHA!!!! You think going to a 45 height tire is going to safe you from NYC pot holes ? HAHAHHHHAAHHA!
    No Marcy D'Arcy, I think that an extra 6/10ths on an inch in sidewall and a softer tire will make my car more comfortable and not as bone jarring when hitting a pot hole.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #22 Re: Will 255/45-18 wheels rub on dna drop springs?
    Quote Originally Posted by buickman104 View Post
    Bahahahahahahahahahahaha you own a GP, if you wanted comfort you should have taken that PA or gotten a Bonne.
    BTW I run the size you are looking into. You still drive through the hell called NYC, good luck haahhahahahahaha
  3. #23 Re: Will 255/45-18 wheels rub on dna drop springs?
    SE Level Member oldsman105's Avatar
    Queens, New York
    Antonio
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  4. #24 Re: Will 255/45-18 wheels rub on dna drop springs?
    If your buddies can't beat you down...who can?
  5. #25 Re: Will 255/45-18 wheels rub on dna drop springs?
    NYC
    My girlfriend(s)...
  6. #26 Re: Will 255/45-18 wheels rub on dna drop springs?
    Kinky bastid
  7. #27 Re: Will 255/45-18 wheels rub on dna drop springs?
    NYC
    UPDATE!
    Well I got the tires and then realized that my rear right side Konig Backbone Rim is 45mm offset when the rest are 35mm (necessary as I have front cts-v brakes). I realized this because once the 25/45/18 tire was mounted, it hit my rear BMR trailing arm. Tried mounting it in the front and it hit my brake caliper. I email Konig as the rims are still under warranty. They told me to call discount tire direct as I bought the rims from them. Called discount tire and they tell me the rim is on national back order until mid September. I call at least 15 wheel dealers that carry Konig and none of them have it. So my car sits with the emergency spare abandoned in the street as I will not be able to get a konig backbone until at least the fall. I decided the best solution is to buy a single black 18"x8" rim with a 35mm offset that caN CLEAR cts_v 4 piston calipers and that kind of matches the other 3 rims so I can at least drive my car for the rest of the summer.
    I ask all the aftermarket wheel experts to suggest a temporary rim for me to buy so I can drive my car until I can get the Konig replaced with a proper 35 mm offset rim in the fall. I don't mind if the rim is not black as I can plasti dip it black.
    http://i1.frsimg.com/images/detailed...d078a36ade.jpg
    Wheel: Konig Backbone
    Wheel pattern: 5-114.3
    Offset:35mm
    Bore Diameter: 73.10mm
    Please open to suggestions to wheels with similar looking spokes and sizes.
  8. #28 Re: Will 255/45-18 wheels rub on dna drop springs? Wheel experts need advice!
    Queens, New York
    heres one
    Will 255/45-18 wheels rub on dna drop springs? Wheel experts need advice! Attached Images
  9. #29 Re: Will 255/45-18 wheels rub on dna drop springs? Wheel experts need advice!
    those 3 piece ronal teddy bears are worth more than most of your cars.
  10. #30 Re: Will 255/45-18 wheels rub on dna drop springs? Wheel experts need advice!
    NYC
    No Enrique I am not putting teddy bears on my car. They look like a negative RWD offset too.
  1. The day I get my drop springs...
    By ZR1Vette09 in forum Off Topic Discussion
    Last Post: 05-10-2010, 10:40 PM
