Thread: Biggest allowable rim size......
Results 1 to 20 of 22
  1. #1 Biggest allowable rim size......
    Nov 2012
    Lebanon, Ohio
    I was just wondering what the biggest rim size is that I could put on my 07 GP without changing the factory setup? Was thinking about 18" rims but wasn't sure of the needed offset.
  2. #2 Re: Biggest allowable rim size......
    Jan 2009
    Tallahassee, FL
    How big do you want, 18s fit no problem in a 30mm-40mm offset.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Biggest allowable rim size......
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    maybe 20'', 19'' for sure, 18'' will look the best though
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  4. #4 Re: Biggest allowable rim size......
    Nov 2012
    Lebanon, Ohio
    That is what I was thinking I was worried however that I might get some rub against the suspension.
    22s fit easy with the right sized tire. Pick what you want, run the right sized tire.
    Please don't let the naysayers sway you here. They just don't know what it is to inform without judging.
  6. #6 Re: Biggest allowable rim size......
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by Spike89 View Post
    Width would be good to know to. A 9" wheel at +40 will fit...keep in mind fender work as well if you go wider or lower offset than that.
    77 Morris Garage B
  7. #7 Re: Biggest allowable rim size......
    Out West
    18" +40 unless you like the wagon wheel thing.
    Whine with your Cheese?
  8. #8 Re: Biggest allowable rim size......
    Nov 2012
    Lebanon, Ohio
    +40? Need some explanation Im not wheel savy.
  9. #9 Re: Biggest allowable rim size......
    Out West
    offset.
  10. #10 Re: Biggest allowable rim size......
    Switch to coilovers and your offset and rim width options change big time with out the damn strut being so wide. So then the question is not how big of a wheel can you fit but how wide or a rim can you fit!!
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    You really don't need anything over a 9" wheel realistically.
    77 Morris Garage B
  12. #12 Re: Biggest allowable rim size......
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by Sandman View Post
    but it's so cool man on a FWD car
    04+ looks better with 20s than 18s unless your dropped.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  13. #13 Re: Biggest allowable rim size......
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by Ridin ON Chrome View Post
    Meh
    77 Morris Garage B
  14. #14 Re: Biggest allowable rim size......
    Houston/Baton Rouge
    Meh
    That's all...Hating on 20s???
    I live here. DirtDog's Avatar
    Jun 2012
    I think u should do 44's
    Sent from my pager using Morse code. ... .. ... ....
  16. #16 Re: Biggest allowable rim size......
    Jan 2009
    Tallahassee, FL
    Yup
    77 Morris Garage B
  17. #17 Re: Biggest allowable rim size......
    SE Level Member Elrodd384's Avatar
    Mar 2012
    Fort Campbell, KY
    Mickey Thompson classics
  18. #18 Re: Biggest allowable rim size......
    if you wanted to do a little fender work and run a not-so-correct tire size, and potentially some aggressive alignment settings, you could get away with 10" wide wheels all day. it's really not that hard, but people are unwilling to work to get things to fit, hense why i never tell people to run big boy sizes.
  19. #19 Re: Biggest allowable rim size......
    Houston/Baton Rouge
    10" wide wheel work, but only with the right offset.
  20. #20 Re: Biggest allowable rim size......
    Nov 2012
    Lebanon, Ohio
    I really only want 18" wheels. So I would need 18x8 w/40 degree offset? What coil overs would be best if I switched?
  1. biggest tire size for stock 5 spoke gp rims
    By mboase in forum Tires & Wheels
    Last Post: 01-29-2013, 05:14 PM
  2. What is the biggest rim size I can fit on my 2001 pontiac grand prix gt coupe?
    By Kevin Ferguson in forum Introductions/Noob Questions
    Last Post: 09-08-2012, 04:33 PM
  3. One of my biggest Questions...
    By jerZcavy4120 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2011, 08:30 PM
  4. biggest POS parts car or?????
    By kuntzie in forum General Tech Discussion
    Last Post: 08-01-2010, 07:49 PM
  5. What is your biggest annoyance
    By lilbear6889 in forum The Rant Forum
    Last Post: 05-04-2010, 01:20 PM
