Thread: Excessive tire squealing. Just read lol
Results 1 to 20 of 28
  1. #1 Excessive tire squealing. Just read lol
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    So lately my tires which have only around 5k miles on them have been squealing excessively. For example doing like 60 degree corners at around 25-30 mph. Or starting at a stoplight, if there is a small amount of water on the ground they slip and squeal a few seconds before they catch.
    This may be suspension related. It might be on the original suspension. All 215k miles of it.
    Any reasons this could be happening? Or should I just slow down? Lol
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Lol if you hit boost when taking off slow down . might just be bad shocks letting all the weight move to the rear and causing less traction up front .
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
    Mar 2012
    Minneapolis MN
    Oh I'm a GT lol but my rpms never go over 2k taking off.
    I think it still has original struts and shocks... :what:
  4. #4 Re: Excessive tire squealing. Just read lol
    try rotating them. you should be rotating every 6,000 miles. or every other oil change.
    Mar 2012
    Minneapolis MN
    I'll get em rotated tomorrow and see if that helps
  6. #6 Re: Excessive tire squealing. Just read lol
    Cheap tires trying to cope with being driven hard?
    Mar 2012
    Minneapolis MN
    My dad did get the roughly 100 dollar multiseason tire....
  8. #8 Re: Excessive tire squealing. Just read lol
    I had something like that, squealing around corners and such.
    Bought something nice and they've been ever so silent and begging to be pushed much more.
  9. #9 Re: Excessive tire squealing. Just read lol
    low air pressure will also make the wheels squeal around corners. cheap tires or not lol
    Mar 2012
    Minneapolis MN
    I may be over thinking this... but like tire air pressure or like climate air pressure
  11. #11 Re: Excessive tire squealing. Just read lol
    Mar 2012
    NC
    Tire air pressure bud.
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by hitman92499 View Post
    The ghost is winning... :what:
  13. #13 Re: Excessive tire squealing. Just read lol
    Mar 2012
    NC
    Quote Originally Posted by Kolton Lock View Post
    LMAO
  14. #14 Re: Excessive tire squealing. Just read lol
    35 psi is what I run.
    Maybe you should just slow down.
  15. #15 Re: Excessive tire squealing. Just read lol
    Mar 2012
    Minneapolis MN
    we shall see lol i will get them rotated and air sometime today
  16. #16 Re: Excessive tire squealing. Just read lol
    When you got the tires ..did you get an alignment?
    Did you whack anything since?
    30ish on a 60 degree corner...please...smack yourself, that's expected.
    Mar 2012
    Minneapolis MN
    Yes they were aligned.
    And yeah I curbed like a mofo last winter. I believe I warped my front left rotor from that
  18. #18 Re: Excessive tire squealing. Just read lol
    This curbing was since the alignment?
    Mar 2012
    Minneapolis MN
    Yep about a month after it
  20. #20 Re: Excessive tire squealing. Just read lol
    St. Louis
    Sounds like you may have bent more than a rotor. Might have screwed up a tie rod end. Might want to have that alignment checked out again.
  1. excessive wheel/road noise after tranny rebuild
    By tonglebeak in forum General Tech Discussion
    Last Post: 08-14-2012, 09:01 PM
  2. Replies: 4
    Last Post: 07-17-2012, 04:39 PM
  3. 98 GTP with excessive pressure in cooloing system
    By phil morris in forum General Grand Prix Discussion
    Last Post: 05-25-2012, 08:39 PM
  4. Excessive Trunk Vibration
    By Kolton Lock in forum Audio, Security & Visual Electronics
    Last Post: 05-03-2012, 06:57 AM
  5. 02 GTP, excessive oil usage
    By Skillet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 07:19 PM
