Thread: Excessive tire squealing. Just read lol
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Excessive tire squealing. Just read lol
    if you bent the rotor....thats kinda hard to do, the rim would also be bent to sh1t. aka smashed!
    if its bent, rotating could make a difference, i'd have it balanced to make sure its not bent sooner or later tho.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Rotated. Feel a whole lot different than it was before.
    A tie rod end though? Couldn't I tell that by looking at it?
    I mean the car still drives straight.
  3. #23 Re: Excessive tire squealing. Just read lol
    jack up a front tire, leave the wheel tight, grab the tire at the 3 o clock position, push and pull, you have almost no play, if a tie rod is bad you will feel it move, maybe even feel a click. do this for both sides.
  4. #24 Re: Excessive tire squealing. Just read lol
    Inner tie rod could be bent throwing alignment off.
  5. #25 Re: Excessive tire squealing. Just read lol
    Kolton.. fwiw after you confirmed my suspicion, the below is how I translate what you wrote:
    "Hi.. I hit something hard and then wonder why my car seems to drive straight, but my tires are shredding off and squealing."
    Maybe I've been playing with cars too long. But this sure seems like it's obviously going to effect the way the car drives.
    Mar 2012
    Minneapolis MN
    You're right... doesn't make sense... but really it makes noise. But still rides straight
  7. #27 Re: Excessive tire squealing. Just read lol
    Seems to ride straight. likely it's pretty far out of whack. I'd suggest an alignment.
  8. #28 Re: Excessive tire squealing. Just read lol
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    If you hit a curb i can almost 100% guarantee you need an alignment.
    I went NA when a whore left -$300 in my bank account.
  1. excessive wheel/road noise after tranny rebuild
    By tonglebeak in forum General Tech Discussion
    Last Post: 08-14-2012, 09:01 PM
  2. Replies: 4
    Last Post: 07-17-2012, 04:39 PM
  3. 98 GTP with excessive pressure in cooloing system
    By phil morris in forum General Grand Prix Discussion
    Last Post: 05-25-2012, 08:39 PM
  4. Excessive Trunk Vibration
    By Kolton Lock in forum Audio, Security & Visual Electronics
    Last Post: 05-03-2012, 06:57 AM
  5. 02 GTP, excessive oil usage
    By Skillet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 07:19 PM
