Thread: How to calculate tire sizes
Results 1 to 8 of 8
  1. #1 How to calculate tire sizes
    SWPA
    I am sure this has been covered in the past, and I think even in my short time here I have posted the formula for calculating tire diameter, but since the question "Will this fit?" comes up so often I figured this deserves its own dedicated thread.
    Stock tire size on my 07 GT is 225/55/17
    225 is the section width in millimeters. To convert that to inches you would divide it by 25.4.
    55 is percentage of diameter that is the sidewall height.
    17 is, obviously, the rim diameter
    The math formula to figure out the overall diameter would be the following:
    ((225/25.4) * .55) * 2) + 17 = 26.744
    If you have Excel you can input the following formula
    =SUM((((A1/25.4)*(B1*0.01)*2)+C1))
    Place the tire size in A1, B1, and C1, and paste the fomula in D1
    So 225 would be in A1, 55 in B1, 17 in C1 and the formula will automatically do the math for you. Since the sidwall height is based on the section width, if you go wider you will get taller unless you also change the sidewall ratio. A lot of people have trouble understaning this concept. You can use the formula to play with different widths and see how it affects the overall height.
    Sure there are plenty of tire size calculators all over the internet, but if you have the formula saved on your desktop you can instantly see if your choice of wheel/tire combo will be too tall, or too short.
  2. #2 Re: How to calculate tire sizes
    Omaha, NE
    So... Based on the example, you could run 275 60 14s and have the same sidewall ratio as your stock wheels.
    225 55 17= 26.74409449
    275 60 14= 26.99212598
    I'm pretty sure 275s would rub though?
  3. #3 Re: How to calculate tire sizes
    SWPA
    Probably would. This is where common sense has to come into play, though. Another factor is wheel offset. Some offsets allow you to run wider tires without rubbing. That's a completely different formula though.
  4. #4 Re: How to calculate tire sizes
    Donating Users
    South Deerfield, MA
    Thank you for spelling this out for the people that didn't know. I have tried explaining this to many people in my lifetime that think the 55 means a wider tire if it is a lower number.
    Regarding Spades comment, that 275 would rub because of the width, not because of diameter. The diameter on your example would be almost equal to stock like you calculated.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: How to calculate tire sizes
    SWPA
    The misconeption comes from the way tire sizing used to be done. I remember getting into an argument about this subject with my dad when I was younger. He insisted that the lower the second number the wider the tire. It took him stopping at a local tire shop to be proven wrong, though he didn't want to admit it.
  6. #6 Re: How to calculate tire sizes
    SWPA
    Quote Originally Posted by simbah View Post
    ON tire sizes for example 225/60/16
    225 is width of tire in millimeters
    60 is sidewall height but this means 60% of tire width
    and 16 is tire rim diameter
    Did you even read the original post?
  7. #7 Re: How to calculate tire sizes
    Omaha, NE
    Incase someone stumbles in here looking for info on slicks:
    Quote Originally Posted by Ridin ON Chrome View Post
    29" will rub on the fenders.
    The most common size is 26 x 9.5"
    You might be able to fit a 27", 28" tall slick is pushing it.
  8. #8 Re: How to calculate tire sizes
    SE Level Member mikes_comp_g's Avatar
    Oct 2008
    Florida
    This link works really welll to figure out different tire, rim, offset sizes.
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    '05 Comp G. Sexy In Black
  1. Led sizes
    By Jakescoots in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2010, 08:17 PM
  2. 16x7 pregens, tire sizes suck....
    By BoostJunki3 in forum Tires & Wheels
    Last Post: 06-16-2010, 03:17 PM
  3. Need to know bolt sizes
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 08:32 PM
  4. 04+ Sway Bar Sizes?
    By aries83 in forum Brakes/Suspension/Chassis
    Last Post: 10-23-2009, 06:48 AM
  5. HUB nut sizes
    By RichCresci in forum General Tech Discussion
    Last Post: 07-27-2008, 12:28 PM
