Thread: 245/40-18 tires on 7.5" Rim?
Results 1 to 16 of 16
  1. #1 245/40-18 tires on 7.5" Rim?
    GTP Level Member buickman104's Avatar
    NYC
    Can I safely run 245/40-18 tires on a 7.5 inch wide Rim?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: 245/40-18 tires on 7.5" Rim?
  3. #3 Re: 245/40-18 tires on 7.5" Rim?
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
  4. #4 Re: 245/40-18 tires on 7.5" Rim?
    Out West
    I'd stick with 235/40/18
  5. #5 Re: 245/40-18 tires on 7.5" Rim?
    Florida
    heck i run 245/45-17's on my 7" wide rims they are fine look nice and square.
  6. #6 Re: 245/40-18 tires on 7.5" Rim?
    Out West
    245 on a 6.5" rim will cup however.
    I guess you're prob safe going 245 on a 7.5" rim
    245/45/18
  7. #7 Re: 245/40-18 tires on 7.5" Rim?
    NYC
    The reason I ask is because I got a really good deal on some barely used Falken tires and they are 245/40-18 i looked at the tire calculators and they suggested an 8 inch wide tire for that size because of the profile.
  8. #8 Re: 245/40-18 tires on 7.5" Rim?
    Wichita
    245/40/18 is what I've got on my rear wheels. They look ok for being a bit short, granted my wheels are 8“wide not 7.5“.
  9. #9 Re: 245/40-18 tires on 7.5" Rim?
    Out West
    I run 235/40/18 on a 18x7.5..
  10. #10 Re: 245/40-18 tires on 7.5" Rim?
    NYC
    Had the tires installed and the car aligned today. The tires are awesome! The car has never handled so good since I owned it...
    "When I bought the car it had 16" Torque Stars with bald stock size tires. The got the charger 18" Rims and needed tires as an emergency so I got 35% tread life 245/45/18 Eagle RS-Poops for like 30 bucks a tire. Once I got those and drove the car around I realized the every time I hit a dip in the Highway the rear fenders would scrape against the sidewall of my tire! Solution!!! Roll my fenders! Did it the cheap $8 home depot PVC pipe with rubber couplers for padding and a heat gun! The rolled fenders came out great!
    Then I drove around with a transmission in the trunk of the car for about 1 week before driving the car up to Bill's to swap the trans. My old trans hit 296 degrees on that jaunt! Drove back with a great mildly built trans! Then when I got to the city I realized that my rear shocks refused to come back up. The trans in the trunk finished off my rear shocks and my front shocks and mounts were worn too! Did the suspension all around. Previous owner had the bright idea to replace his warn shocks with junkyard pulled units! That is why they failed so soon on me!
    That completely threw off my alignment. I tried to get an alignment, but an alignment shop game me some BS about my warn tires and tried to forcefully sell me $800 worth of stock size 225 series new tires from them. I said I didn't have that kind of money. They replied just put it on your credit card and pay them off in installments. I replied, "F-ck Off! and left pissed." Drove the eagle RS-A's until they are bald on the toe in from being so bad out of alignment. Started looking on craigslist for some good condition 245 series tires. After 3 weeks of searching I finally came across my Falken Ziex tires for $200, up in Westchester. Drove up saw they were practically new with about 85% tread left bought them and drove them back."
    The alignment shop game me the heads up that I need a new driver side wheel bearing and my inner tie rod ends were still good, but a little worn and probably should change them around the time I feel I need my next alignment.
    Now with the alignment and great meats on the car it handles like it never did before (i know it handles like a FWD boat, but I never felt this car with good tires, so to me it feels like a corvette right now! :P)
    The only issue I need to figure out is why the steering wheel violently rocks left and right when braking to a stop above 25MPH. I am guessing it is because of the bad wheel bearing, but I have a feeling my CV axles are popping ever so slightly!
    So far that is my story and I am sticking to it!
  11. #11 Re: 245/40-18 tires on 7.5" Rim?
    Portland Oregon
    Quote Originally Posted by Nixon View Post
    Are those police charger wheels?
  12. #12 Re: 245/40-18 tires on 7.5" Rim?
    NYC
    With the smaller profile and Intrigue springs my car looks like it is on stilts! LOL
  13. #13 Re: 245/40-18 tires on 7.5" Rim?
    Out West
    Quote Originally Posted by OH4CompG View Post
    YES!
    Whine with your Cheese?
  14. #14 Re: 245/40-18 tires on 7.5" Rim?
    Out West
    Quote Originally Posted by buickman104 View Post
    Rotors.
  15. #15 Re: 245/40-18 tires on 7.5" Rim?
    NYC
    I thought that too, but i don'[t feel the vibration through the brake pedal. I only feel it through the steering wheel.
  16. #16 Re: 245/40-18 tires on 7.5" Rim?
    Iowa
    Front rotors you will feel in the wheel more, rears you will feel in the pedal more.
  1. WTB - 18" Wheels and Tires
    By TITAN in forum West
    Last Post: 12-14-2011, 11:49 PM
  2. Replace 15" tires with 16" tires
    By maxim08 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:44 PM
