Thread: Do I need an alignment?
Results 1 to 4 of 4
  1. #1 Do I need an alignment?
    Fargo, ND
    Short and to the point. The inside 1/3 section of my tires have been wearing a lot faster than the outer 2/3. Does this indicate an alignment is needed? The car steers arrow straight....
  2. #2 Re: Do I need an alignment?
    take a tape measure and measure from the middle of the tread on the back of the tire to the middle of the tread on the back of the other tire and see what the measurement is then do the same to the front of the tire. It should be the exact same measurement.
  3. #3 Re: Do I need an alignment?
    Buffalo
    If you have to ask, then yes. Should check to make sure your ball joints / tie rod ends are not bad, causing the bad alignment first. Then get one
  4. #4 Re: Do I need an alignment?
    you probably have too much tow. it is wearing the inner tread on the tires because you have sagging springs from high mileage and more camber than usually comes stock.
    this is my bet, but yes. get an alignment.
  1. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  2. Alignment
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2011, 10:39 AM
  3. Alignment
    By matt5112 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2010, 03:51 AM
  4. Alignment kits?
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2010, 04:13 PM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
