Thread: Tire Air Pressure
Results 1 to 8 of 8
  1. #1 Tire Air Pressure
    Louisville, KY
    I've got new set of 17X8 rims with 235/55-17 Eagle RS-A. Tire says max pressure 44 lbs. When I got the tires put on the shop set the pressure at 44lbs.
    Do I really need that much or is there another pressure I should be running at?
    My Cardomain
  2. #2 Re: Tire Air Pressure
    Wichita, KS
    35 PSI all the way around is what I sport.
    When I go to the track, I will run around 12PSI in my front slicks, and pump up the rears to the MAX rated PSI which I believe is 44PSI for mine as well.
    ~F~
  3. #3 Re: Tire Air Pressure
    Feb 2008
    I agree. 35 PSI is the way to go.
  4. #4 Re: Tire Air Pressure
    May 2008
    staten island,NY
    i do 30psi, NYC sucks
  5. #5 Re: Tire Air Pressure
    Donating Users crshoveride's Avatar
    Pearl, MS
    yea normal driving you shouldn't need 44 psi. as with the others i run bout 35 psi.
    1998 Grand Prix GTP Stock for now mods to come soon. Alpine 9885 head unit, 2 JLW3V2 10s, 2 Jensen 650x2 amps, and Tsunami wiring all the way around.
    Ladies and gentleman take my advice. pull down your pants and slide on the ice
  6. #6 Re: Tire Air Pressure
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    The max tire pressure printed on the sidewall is the maximum pressure, not what they should normally be set to.
    Draw a chalk line across your tires, then drive for a little bit. If the chalk line wears evenly, then your tire pressure is good. If the center wears first, your pressure is too high. If the edges wear first, your pressure is too low.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  7. #7 Re: Tire Air Pressure
    Louisville, KY
    Thanks!
    My Cardomain
  8. #8 Re: Tire Air Pressure
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    i run 35-36.
    GO by what your car tells you on that sticker
    Max pressue is bad wears tires out fast and hit a pot hole can bend rim a lot easier. That is there for if the car is fully loaded down with its max weight
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  1. ABS and Tire Pressure Lights on
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2010, 10:05 PM
  2. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  3. Low Oil Pressure?!?!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 03:07 PM
  4. Tire Pressure System not working.
    By xray328 in forum General Tech Discussion
    Last Post: 05-13-2008, 08:43 AM
  5. ABS and Check Tire Pressure with hard steering
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-09-2008, 04:32 PM
