Thread: how to clean rotors & calipers?
Results 1 to 3 of 3
  1. #1 how to clean rotors & calipers?
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    What is the best way to clean painted calipers and drilled rotors?
    Also looking to rotate my own tires.
    Thinking about getting a 2 ton jack and some stands, take the tires off, hand clean the calipers and rotors still on the axles and then put the tires back on rotated, any sense to this or no?
    Sense I could have two tires off at a time, they wouldn't be properly criss crossed rotated though, just side to side.
  2. #2 Re: how to clean rotors & calipers?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Rotating the tires can be done cris-crossed or rotated front to back on the same sides. It depends on the type of tread design. Some high performance tires are uni-directional. That means they can only roll one direction so they must stay on that side of the car.
    I have used Meguiar's chrome wheels cleaner on my rims and it seems to get the painted calipers real clean too. Brake cleaner will clean up your rotors but I don't know if it would take the paint off your calipers or not?
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: how to clean rotors & calipers?
    Just use a moist rag on the calipers and stay away from brake cleaner it will strip the paint. For the rims I use a wet rag and wipe away but I clean them constantly so they're east to wipe
    04 Comp G.
  1. Replies: 12
    Last Post: 08-10-2011, 12:08 PM
  2. Looking to get new rotors and painted calipers, how much?
    By tcman49 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2011, 02:20 PM
  3. Want new calipers, rotors, and pads, but...
    By LALAW in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 08:24 PM
