Thread: GM hub assembly warranty?
Results 1 to 4 of 4
  1. #1 GM hub assembly warranty?
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I may not get anything out of it, but the hub I replaced last weekend was previously replaced two years/35,000 miles ago. I'm pretty sure it was a GM hub assembly, since the shop receipt says it was $240. I know some of the better hubs have 3 year warranties, but they may only offer that to the shop. Best case, the shop can return the broken hub and get the dealership to replace it and they give it to me. But if GM's warranty is only 2 years/25,000 miles, I'm out of luck.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: GM hub assembly warranty?
    SE Level Member BLWNPontiacs's Avatar
    Sep 2011
    Bucks County PA
    I should remember this since I used to be a GM Service Writer but I believe it's a 1yr/12,000 mile warranty. If it was only $240 I doubt it's a GM hub, they're usually more expensive. NO aftermarket hub that I know of has a 3yr warranty.
    -09 BMW 328i Xdrive
    -06 LSM GXP-Factory Nav & moonroof, stock...for now.
    -98 Silvermist GTP Coupe-Getting junked or parted out.
    -09 G8 GT-Totaled due to some dumbass 18yr old kid
  3. #3 Re: GM hub assembly warranty?
    Feb 2008
    Cumming GA
    Ok, thanks. And I guess I was looking at another part, because sure enough, most of the RockAuto hubs are 1 year warrenty. But still, that hub should not have died in TWO years, since the other side hub was on the car when I bought it, and I've put about 80k miles on it since then.
    I also don't think it's any way I drive, since the hub I replaced on my Impala was driver's front, and this was the passenger front. I just wish I was a little more careful when I removed the one good one that was on my Impala, as I could have used it as a replacement instead of buying a new one. But it was stubborn coming off, and I managed to rip off the ABS plug.
  4. #4 Re: GM hub assembly warranty?
    Sep 2011
    Bucks County PA
    Aftermarket ones are hit or miss...it's a risk. But yeah it should last over 2yrs regardless of the brand.
    -09 BMW 328i Xdrive
  1. Aftermarket Warranty
    By brian0488 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:42 PM
  2. Mods + Warranty
    By KenH83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2008, 01:52 PM
