Thread: Tire size and rating information
Results 21 to 40 of 54
  1. #21 Re: Tire size and rating information
    Donating User Odi's Avatar
    Chicago South Suburbs
    Quote Originally Posted by eightyseven View Post
    I probably sound stupid, but if the rim was on 235 tire, don't I need a new 235 tire? 245 would work on the rim?
    yes, stupid question. u can put other sized tires on a rim. 245/45 is the perfect size for 18 in wheel.
  2. #22 Re: Tire size and rating information
    SE Level Member techweenie's Avatar
    Nov 2009
    Grand Blanc, MI
    I just got new wheels and tires, and I'm sharing some info so you'll know. I was told 235/55R17 tires would fit perfectly but, in fact, they ever so slightly rub on the struts in the back. The wheels are 17x7.5 with 42mm backspacing. A little less backspacing would eliminate the problem and look better too.
  3. #23 Re: Tire size and rating information
    if they are rubbing the strut, you want less offset to push the wheel farther away from the strut. however, in your case i expect something else to be wrong because those specs should be super easy to fit without rubbing, tires and wheels.
  4. #24 Re: Tire size and rating information
    Nov 2009
    Grand Blanc, MI
    I realized my mistake and edited the post. They rub on the spring seat, but just BARELY.
  5. #25 Re: Tire size and rating information
    SE Level Member kurt5153's Avatar
    Apple Valley,Ca 92308
    For those of us that are gonna drop back to stock(16s) or 15s whats the widest we can fit 245s?
  6. #26 Re: Tire size and rating information
    Feb 2008
    For a stock 6.5" wide wheel, I would recommend you not go wider than 235mm, but a 245/55-16 will fit. You may have to use a small spacer to keep the inside of the tire from rubbing, though.
  7. #27 Re: Tire size and rating information
    225 is already too wide for stock wheel.
    225 is 8.9" wide, 7" wide wheels make the sidewalls straighter, handle better, less chance of cupping.
  8. #28 Re: Tire size and rating information
    Feb 2008
    Very true! I was just answering the question on whether or not they would fit... indeed, anything wider than 225 on a stock wheel will tend to cup.
  9. #29 Re: Tire size and rating information
    thxs! is the stock rim with 6" or 7.5" wide?
  10. #30 Re: Tire size and rating information
    Feb 2008
    6.5", I believe.
  11. #31 Re: Tire size and rating information
    i wouldnt put 245/50's on a 6.5'' wheel since it is not recommended by any tire manufacturer to do so. i am putting them on a 7'' wheel tho.
  12. #32 Re: Tire size and rating information
    i would recommend 245/50/16 on the stock wheels without issues.
  13. #33 Re: Tire size and rating information
    Yoga city
    Sweet my tires are rated for 186mph go w! 225/35zr20 90w
  14. #34 Re: Tire size and rating information
    90 is pretty low.
    and that gets lower the faster you go.
  15. #35 Re: Tire size and rating information
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Getting some Pulse 17" wheels which are 7.5 wide. Thinking about getting tires in the 225/55 size. Thinking about running Eagle GT's. Thoughts on these tires or other mid priced tires that you would recommend would be appreciated.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  16. #36 Re: Tire size and rating information
    stay with the stock overall diameter. 225/50 is short and ooglay.
  17. #37 Re: Tire size and rating information
    Iowa
    Quote Originally Posted by webracin View Post
    18 Inch Rims
    245/45R18 Stock diameter.
    Should add that GXP stockers are staggered 255/45R18 front and 225/50R18 rear
  18. #38 Re: Tire size and rating information
    SE Level Member rocketman1989's Avatar
    Dec 2011
    Ottawa, KS
    Sorry Guys, this isn't quite the right place for this I don't think... I'm a Budget Enthusiast and Need new tires so I'm taking suggestions. Sticking with stock Wheels and size: 225 60 R16 98 H-V Lookin for an all Season.
    Priorities in order are:
    Long Life
    Good Grip in ALL seasons
    Performance
    Low Roll Resistance
    Ride Comfort
    Noise Level
    Was looking at the GeneralTire Altimax HP... thoughts or suggestions?
    Last edited by rocketman1989; 12-04-2011 at 06:19 AM. Reason: Wrong Thread Location
  19. #39 Re: Tire size and rating information
    SE Level Member ralanc's Avatar
    Jax, FL
    I have a 2006 GXP. I am ready to replace my tires.
    I have 245/45R/18's and stock Alcoa wheels all around that came with on the car when I bought it used, but I am leaning towards getting a staggered set to oem specs.
    I dont see anyone talking about stock tires. I know they are expensive. ( I will be paying $1025 out the door at Discount Tire here in Jax, FL.)
    Other than cost are there any other compelling reasons I shouldn't go with 255/45R/18's upfront and 225/50R/18 out back?
    Do that set up perform badly?
    Do they wear out quickly since I cant rotate?
    Does mileage suffer.
    Do they look weird?
    Thanks in advance for any input.
  20. #40 Re: Tire size and rating information
    being able to rotate the tires is helpful for tire wear and life. i would never put a staggered setup on any car i own..
  1. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
  2. recommend tire size for 17x9 bullitt
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 03:48 AM
  3. UserCP not updating information?
    By SD GTP in forum Forum Bugs/Suggestions
    Last Post: 02-18-2008, 01:44 PM
  4. 17x9 okay? what tire size?
    By Bio248 in forum Tires & Wheels
    Last Post: 02-15-2008, 02:09 AM
  5. Some interesting Eaton Information
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2008, 05:31 PM
