Thread: Tire size and rating information
Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
  1. #41 Re: Tire size and rating information
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    The staggered setup sucks. I bought my Gxp a little over a year ago. The tires (255/45/ZR18) were in great condition (2k wear) when I got the car. The tires were Hankook Ventus Es4's. In July I replaced the front tires with two new Hankook's. I will be replacing them again this summer. It's not an alignment issue as all is in specs there. Maybe it's the type of tire idk. As for the rears, they were the same brand and stock size 225/50/ZR18. The wear is good. The problem is now they are noisy because I can't rotate them. They will also need to be replaced this summer. I will be going with 245/45/ZR18 all around this time.
    Edit: Tire name was incorrect.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  2. #42 Re: Tire size and rating information
    May 2013
    Ontario Canada
    Can i put 235 55 17's on a stock '03 grand prix gt? Set of winters that just came with my gxp. Rims are 17 x 7. They say +42 on the inside..not sure if that means anything. They look like plain ol fwd rims. Is there a risk of any rubbing thats my first concern
    Thx guys
    Ron
  3. #43 Re: Tire size and rating information
    Jul 2010
    Detroit
    You won't have any rubbing issues.
    Ryan
  4. #44 Re: Tire size and rating information
    Kemmerer, Wyoming
    is anyone putting slicks on their stock wheels 16 X 6.5? I found a mickey thompson 255/50/r16 but im not sure if it will be too wide for a stock wheel.
  5. #45 Re: Tire size and rating information
    people have done it. i wouldn't be driving around on them, but if you're using it for straight line track action you should be okay.
    you might be better off finding a set of wheels that are 16x7 or 16x8 just for that purpose, though.
  6. #46 Re: Tire size and rating information
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Gonna be buying new tires soon. In the link below, Bio recommends 245/50/16 for the stock wheels. That was 7 years ago. Is that a good size to be Googling for my 16" torque stars? Please Advise.
    Link to Bio's recommendation: http://www.grandprixforums.com/tires...tml#post596564
    JEGS has them for $120 per tire:
    BF Goodrich 65801: G-Force Comp-2 All Season Tire 245/50ZR16 | JEGS
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  7. #47 Re: Tire size and rating information
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by CHI2000GTP View Post
    The "Z" is the speed rating. Upwards of a sustained 149 m.p.h. Not sure you're gonna need that. Lower speed rated tires are gonna be cheaper, I imagine....
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  8. #48 Re: Tire size and rating information
    Dec 2015
    Chicago, IL
    LOL. Yeah, don't think I need the Z. But is that size OK, 245? Stock is 225. I'm worried about that. Bio seemed to know what he was talking about, from what I've gathered reading his other posts... But that was many years ago when he was a regular on here.
    Just wanting to make sure that 245 size will work on the stock rims.
    243,000 miles
    CHICAGO, IL
  9. #49 Re: Tire size and rating information
    245's work better on a 7in or 7.5in rim.
    They fit on the factory 6.5in rims but look goofy to me, even BGF says you need a 7in for proper fitment and ride quality. I'd rather run the factory size to have far more tire options.
    Think non directional tires too, you will get longer life you can do regular rotations that aren't front to back only.
  10. #50 Re: Tire size and rating information
    Dec 2015
    Chicago, IL
    Ok. Ten four. I k ow you said factory sieze, but how about 235? Right in da middle. I want that wider stance, wider tire look. Anything helps.
    What are you thoughts on spacers? Lots of guys use em, but the "car pros" on many websites say they're not safe and shouldn't be used.
  11. #51 Re: Tire size and rating information
    You won't find many tires in the 235/55/16 size though.
    Changing the offset is the only way to make the stance look better. I ran 225/60/16's on 94-96 rims that were +25 compared to the +52 that torq stars are. They looked great because of the offset difference. I've never run spacers so I can't comment there.
  12. #52 Re: Tire size and rating information
    SE Level Member Yodawg's Avatar
    Sep 2016
    Indiana
    Will 2011-2014 18" x 9 charger wheels fit 97-03 Grand Prix? What size tire recommended?
  13. #53 Re: Tire size and rating information
    Google brah.
    Yes, bolt pattern is the same. Bore size is super close, only 1mm difference. Offset I couldn't find and 245/45/18's are what you need for 18's to keep the speedo the same.
    Rolling the fenders in a must on 9in wide wheels and if the offset doesn't work they will rub the strut towers.
  14. #54 Re: Tire size and rating information
    Sep 2016
    Indiana
    Ok thanks!
  1. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
  2. recommend tire size for 17x9 bullitt
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 03:48 AM
  3. UserCP not updating information?
    By SD GTP in forum Forum Bugs/Suggestions
    Last Post: 02-18-2008, 01:44 PM
  4. 17x9 okay? what tire size?
    By Bio248 in forum Tires & Wheels
    Last Post: 02-15-2008, 02:09 AM
  5. Some interesting Eaton Information
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2008, 05:31 PM
