Thread: Tire Size??
Results 1 to 11 of 11
  1. #1 Tire Size??
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    gotta buy tires again for the 05 grand prix there are 18 inch wheels whats the best tire size to buy??
    Currently theres 245/45/18.
    its not lowered or anything just normal ride height.
  2. #2 Re: Tire Size??
    SWPA
    Stick with the 245/45/18's.
  3. #3 Re: Tire Size??
    buy the same size. that is the closest to stock overall diameter you can get.
  4. #4 Re: Tire Size??
    Pittsburgh, Pa
    what bout 245/40/18?
    there lot cheaper
  5. #5 Re: Tire Size??
    they also shorter than stock and will increase your wheel gap and look retarded.
    your choice.
  6. #6 Re: Tire Size??
    Pittsburgh, Pa
    oh okay i thought they were just wider
  7. #7 Re: Tire Size??
    Pittsburgh, Pa
    tire rack is sayin 235/50/18 whats tht size look like
  8. #8 Re: Tire Size??
    245/45/18 and 245/40/18 are the same width of tread, but the sidewall is smaller. the second number is an aspect ratio of the first number, so the sidewall height is a percentage of the tread width.
    just run with 245/45/18 and be done with it. 235/50/18 isnt the best size.
  9. #9 Re: Tire Size??
    SWPA
    Quote Originally Posted by 2005GrandPrix View Post
    Why would they be wider?
    Tire sizes are figured out this way
    245/45/18
    245 is the width in millimeters
    45 is the section width to determine the sidewall height so 45% of 245 mm is the height of the sidewall
    18 is the rim size
    So if you want to figure out the diameter you do this
    245/25.4 = 9.65"
    (9.65 x .45) X 2 = 8.685
    8.685 + 18 = 26.685" tall
  10. #10 Re: Tire Size??
    GT Level Member Lenny's Avatar
    Jul 2010
    41 R QR 51938 02935
    too much math for me. this is easier to remember: 245/45/18 = good
    2007 Grand Prix GXP
  11. #11 Re: Tire Size??
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    damn dude, can you READ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    235/50 are fine, but will look like off road tires..
    just stick with 245/45s
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Tire Size
    By Hawkins97 in forum Tires & Wheels
    Last Post: 08-07-2010, 01:00 AM
  2. What size tire can I fit???
    By Bigbm80 in forum Tires & Wheels
    Last Post: 04-28-2010, 10:02 PM
  3. Tire size 235/55?
    By RedLedbetter in forum Tires & Wheels
    Last Post: 05-09-2009, 02:14 PM
  4. What size of tire do i need?
    By cboth686 in forum Tires & Wheels
    Last Post: 04-03-2009, 07:17 PM
  5. is it ok to mix tire size?
    By nemesis in forum Tires & Wheels
    Last Post: 07-20-2008, 12:36 AM
