Thread: 17 inch rims
Results 1 to 5 of 5
  1. #1 17 inch rims
    SE Level Member Logan2992's Avatar
    Apr 2011
    Colfax
    I currently have 6" x 6.5", 5 Lug, 115mm Bolt Pattern rims with P225/60R16 tires. I was wondering if i would be able to go up to a 17 inch rim, if so what size tire i would use?
    Thanks!
  2. #2 Re: 17 inch rims
    West Side Michigan
    235-55-17 is a good size tire for 17's
  3. #3 Re: 17 inch rims
    I live here. TLSheff's Avatar
    245-50-17 are almost a perfect replacement for overall diameter (will keep your speedo accurate)
    245-45-17s work but slightly smaller so it will be just barely off, but this is the common size fire for mustangs and other cars so there is a BROAD selection to choose from
  4. #4 Re: 17 inch rims
    SE Level Member techweenie's Avatar
    Nov 2009
    Grand Blanc, MI
    Quote Originally Posted by nawarkk View Post
    I just put this size on my car and they ever so slightly rub the struts on the back. That's with a 42mm offset wheel. A smaller offset would fix the issue.
  5. #5 Re: 17 inch rims
    i already answered your concern in another thread. no need to spam all over the place.
  1. 20 inch rims on 01 GTP wil they fit? Rub?
    By timmaayy2323 in forum Detailing Tips and Tricks
    Last Post: 01-28-2011, 02:07 AM
  2. 20 inch rims questions
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2009, 09:32 AM
