anybody run srt wheels or replicas that arnt 20's.
ah, and i really dont know what size works with what offset, never been good at that thing.
Ooooohhhhh gotcha
the way they stick out it looks stupid. just sayin.
Run some nice negative camber & a set of narrower lower profile tires to fix it. Maybe. Look & you'll see the tire sticks out nearly an inch past the fender. Also the 275 wide tire(stock might be 245 idk) was rubbing against the strut top. And the rims hardly clear the sides of the caliper. In fact I think they rub the caliper. Upgrading to a lerger set of brakes wouuld probablyy fix that. If someone wants to try a set of SRT rims & DD them I'd like to see them do it. It is possible.
Can you get more pictures? Or did you only try one rim? Cause the rears look different.
I kinda like them, if they stick out on the fronts, that means they should be close to perfect on the rears.
My buddy was putting halo rings in his headlights. So his front wheels were off. I figured I'd just see if they fit. I only tried the one wheel &.it looks like chit it does.
Now if there was a way to run them without hitting in the front id get some.
yaaaaaaaaa, stick waaaaaayyyyyy out.
