Thread: tire sizing (wider)
Results 1 to 6 of 6
  1. #1 tire sizing (wider)
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    so i read the sticky, didnt help much. ive always just gotten the stock size for replacement, but im thinking of going a bit wider. all on the stock 16's.
    so stock is 225/60/16
    is 245/55/16 the same thing, just a bit wider? i cant for the life of me figure out what all the dimensions and what not are. i went to an online tire calculator and it comes out pretty damn close to what the stock is, but i still dont know if it's actually wider?
    is the Section Width the actual width of the tire? and is the Rim Width Range gunna be a problem on the stock 16s?
    terrible with numbers any help would be GREAT
  2. #2 Re: tire sizing (wider)
    245's are too wide for stock wheel.
    stock wheels are 6.5" wide. Note under the 245 side it says to use a 7-9" wide wheel.
  3. #3 Re: tire sizing (wider)
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    Quote Originally Posted by oneil.GTP
    yes. and yes, stock rims are 6.5" wide.
    what site did you take the tables from?
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  4. #4 Re: tire sizing (wider)
    a) you can run 245s on a wheel that is 6.5" wide. done it. drove it hard.
    b) you are gonna want to get 245/50/16. slightly smaller sidewall, but the tire size is way easier to find. this is the size i ran.
    c) yes, section width is the actual width of the tire. the same size tire from different companies can vary in actual width pretty drastically.
  5. #5 Re: tire sizing (wider)
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    Quote Originally Posted by noreasonwhyy View Post
    Those tables look to be from 1010tires.com They have a great tire size calculator.
    As for running 245s on a 7" rim, that's probably as high as you can reasonably go, without going to the extremes that I've seen some auto-x cars do.
    my $.02
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  6. #6 Re: tire sizing (wider)
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    255 is as wide as you want to go on stock rims.
    but I wouldnt use them for the street, only for DRs at the track. Just my opinion.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Signature rules
    By Bio248 in forum Site/Club News
    Last Post: 05-19-2011, 04:14 PM
  2. Old tire fun
    By EJOUIE in forum Off Topic Discussion
    Last Post: 04-08-2010, 11:03 PM
  3. SS IC Pulley Sizing
    By a3gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2009, 12:43 PM
  4. tire rack ? about this tire
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 03-09-2009, 09:12 PM
  5. Tire sizing??
    By Quicksilver_GP in forum Tires & Wheels
    Last Post: 04-26-2008, 02:44 PM
