Thread: Easy way to install a new wheel stud?
Results 1 to 7 of 7
  1. #1 Easy way to install a new wheel stud?
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    One of my wheel studs got stripped as I was putting the lug net back on. I got the bad stud out fine with a hammer. Now I'm hoping to put the new stud in without removing the hub. Any suggestions? This is for a front wheel. I can't get a good angle with a hammer.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Easy way to install a new wheel stud?
    Banned - Busted For Scamming
    Feb 2009
    You just put the stud in, put some washers with the lug nut and tighten it up till it pulls through.
  3. #3 Re: Easy way to install a new wheel stud?
    Feb 2008
    Cumming GA
    Ah, that's it. Thanks. I was trying to use a clamp, a screwdriver, all sorts of things. When I tried just putting the lug nut on, it was eating into the rotor. Some large washers will do it. Thanks!
  4. #4 Re: Easy way to install a new wheel stud?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    either that or a wrench with a open ended socket and just keep turning it until its tight.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  5. #5 Re: Easy way to install a new wheel stud?
    Feb 2008
    Cumming GA
    In my other thread regarding the brake job itself, it was suggested to just put the wheel on and tighten it up. It pulled the stud along, and when it couldn't tighten it by hand anymore, I knew it was through. Put about 35 miles on it as I drove to Autozone to return some stuff, no problem.
  6. #6 Re: Easy way to install a new wheel stud?
    Aug 2008
    KCMO
    i would check it again and make sure it got pulled through all the way. can never be to safe
  7. #7 Re: Easy way to install a new wheel stud?
    Top Swap in Progress bigtom9492's Avatar
    Dutchess county
    They are a pain in the ass... you just have to man up and go hard at it.. when you think its in all the way pull in 2 more times. The studs rely on you pulling them into the metal so they bite into it.
  1. How easy is it to replace a bad wheel bearing?
    By Bjm5295 in forum Tires & Wheels
    Last Post: 05-28-2010, 01:02 PM
  2. Stud removal
    By TheOtherNick in forum How To Write-Ups/Tech Tips
    Last Post: 01-04-2009, 11:21 PM
  3. How to fix broken wheel stud?
    By ryangtp89 in forum Brakes/Suspension/Chassis
    Last Post: 10-08-2008, 10:59 PM
  4. &#@$ing Wheel Stud
    By Abrasive in forum The Rant Forum
    Last Post: 04-01-2008, 05:44 PM
  5. rear wheel stud-how to get it out and new installed?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2008, 03:47 PM
