Thread: traction
Results 1 to 18 of 18
  1. #1 traction
    SE Level Member m3ta77ica's Avatar
    Illinois
    so i raced my car friday ran a 14.83 at 94mph wasnt too bad just ****ty and i mean absolutely ****ty reaction time every run. i have to leave traction control on for launch which i would like to get rid of. what kind of tires do yall recomend for an all season performance/drag tire???? i just need to not spin on the line but also drive everyday all year round.
  2. #2 Re: traction
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Well u know reaction time has nothing to do with ur 1/4 time. But, I didn't do too bad on traction. I just revved the botch to 2grand and stepped onto it
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  3. #3 Re: traction
    Moore, Oklahoma
    I've tried all sorts of tires over the years, honestly, there is NO good all season + drag tires that will work good on these cars. Nowadays I run my BFG Traction T/A V-rated tires for the street and when I go to the strip, I put on my Hoosier QTP slicks on and have some real run. I not only save on street tires, but I actully hook too...
    Shawn W. Larsen
  4. #4 Re: traction
    Illinois
    my first run i tried w/ out t/c on and i spun till the 1/8th. traction has to do with my reaction time. i didn't say ne thing bout my 1/4 mile i just said what it was.
  5. #5 Re: traction
    you have to learn to launch the car better. i could get my car to barely squeak the tires on fairly cheap all seasons while getting a good launch.
  6. #6 Re: traction
    Illinois
    i just preload to 2000 n on the 3rd yellow i give it hell and i get a 2.0 light and i can feel the traction control jerk me and slow it down right when i go.
  7. #7 Re: traction
    you cant just slam it to the floor. you have to feather the throttle or ease into it.
  8. #8 Re: traction
    Illinois
    im not just going for a run id like to do a class so i need good reaction and good time and easing into it wont work.
  9. #9 Re: traction
    easing into it will work. thats how you have to drive these cars unless you put slicks on it.
  10. #10 Re: traction
    Illinois
    but how is it possible to be consistent if i ease into it every time. thats almost impossible to ease into the exact same way every pass. Well drag radials should work if there are 400 plus hp cars runnin on em and not spinning.
  11. #11 Re: traction
    you will spin drag radials too. you need SLICKS. consistency is based upon the driver mod. you need to practice.
  12. #12 Re: traction
    SE Level Member bensett004's Avatar
    michigan
    why ask for advice if your going to contradict everything we say?
    fwi, kn filter, 3 in down pipe, power log, 180* thermostat, 10000k hids and soon to come a dhp pcm
  13. #13 Re: traction
    Joliet, IL
    launching....
    load the TC to about 2k via brake torquing....
    when you decide to launch let off the brake....
    at a moderate pace start to press the gas in and once you hear a chirp/squeel then you can mash it.....
    you will learn your car and how fast you can move the gas pedal down and still hook....or like bio said buy slicks and be done with it....but if you practice your launches you will perfect them....i still havent perfected mine it takes practice....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  14. #14 Re: traction
    Joliet, IL
    Quote Originally Posted by bensett004 View Post
    x2 if your gonna ask for help take the advice or your right back where you started.....
    00 Silvermist GTP
  15. #15 Re: traction
    Destroys cars izup69's Avatar
    Iowa
    I say just mash the gas u will smoke the tires but at least it will look cool
  16. #16 Re: traction
    Illinois
    i just came to the wrong place to ask about drag racing.
  17. #17 Re: traction
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by m3ta77ica View Post
    You should try this attitude of yours on less friendly forums, like ClubGP...you will come back here crying "thank you" and begging for more help. These guys have been more than patient trying to help you, but you are not listening. If you think you know better, you tell us the answer to your question.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  18. #18 Re: traction
    i told you everything you need to know. this is a roots blown FWD car. you cannot just lay into the pedal and expect the tires not to spin regardless of your wheel and tire setup. you need to practice your launches in order to get them to be good.
  1. ABS/Traction Lights On
    By Strype in forum General Tech Discussion
    Last Post: 10-01-2009, 07:50 PM
  2. traction control?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2009, 08:56 PM
  3. Traction Control
    By tynev7 in forum General Tech Discussion
    Last Post: 08-18-2009, 10:55 PM
  4. ABS/Traction control
    By holsports in forum General Tech Discussion
    Last Post: 03-22-2009, 11:32 AM
  5. ABS / Traction Light
    By bcrosby51 in forum General Tech Discussion
    Last Post: 12-20-2008, 06:10 PM
