Thread: Wheel spacers/hub rings?
Results 1 to 7 of 7
  1. #1 Wheel spacers/hub rings?
    Moore, Oklahoma
    Any body use em? where can I get em?
    Shawn W. Larsen
  2. #2 Re: Wheel spacers/hub rings?
    do you want wheel spacers or hub rings? they are completely different.
    i would check out your local tire/wheel dealers. thatd probably be the cheapest place to find them.
  3. #3 Re: Wheel spacers/hub rings?
    GT Level Member jasonball's Avatar
    Nov 2008
    ft. mitchell
    hub rings i alway recommend. they help keep center for the wheel. spaces I do not suggest.
  4. #4 Re: Wheel spacers/hub rings?
    Moore, Oklahoma
    Hub rings would probably be the best, don't they reuse the stock studs to bolt on the ring, and have its own studs to bolt on your wheels?
    Shawn W. Larsen
  5. #5 Re: Wheel spacers/hub rings?
    Nov 2008
    ft. mitchell
    no. that sounds like a wheel adapater to where you changer you lug pattern. hub rings are thin and they assist with the centering of your wheel when mounted. I reccommend hub rings with any after market wheels.
  6. #6 Re: Wheel spacers/hub rings?
    Moore, Oklahoma
    With hub rings you're gonna need longer studs aren't ya?
    Shawn W. Larsen
  7. #7 Re: Wheel spacers/hub rings?
    Nov 2008
    ft. mitchell
    no. most wheel companies will send you a set of centric hub rings with your wheels if your request then. or go to like a big10 tire or any wheel shop. they will have them set of 4 for like 20 bucks.
    now wheel spacers you will lose some lenght of your stud.
  1. spacers?
    By crywolf in forum Tires & Wheels
    Last Post: 12-29-2008, 12:49 PM
  2. 5x115 1" Wheel Spacers
    By armcclure in forum Tires & Wheels
    Last Post: 10-12-2008, 01:22 PM
