Thread: Stock Steel Rim options
Results 1 to 5 of 5
  1. #1 Stock Steel Rim options
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I have read the sticky wheel post and through some of the posts. I get more confused the more I read. Sorry I have cognitive issues.
    What I am looking for are a nice set of new black steel rims in stock size for my 07 Grand Prix GT. From what I have read the stock size of these are 17 x 7.5 and have a lug pattern of 5/115mm. I am confused on the offset aspect of the rims.
    I am going to put on new stock tires Falken G5 225/55/17. I want steel rims because the roads around here demolish the alloy. And the weak aftermarket alloy rims will probably get obliterated from the pot holes here. I was looking at the stock rims Friday and one of them have a decent bend, two of them have cracks and another has a previous repair. I looked into getting them repaired and it is just as much money as a new rim.
    Does anyone have any recommendations on some decent looking steel wheels for these cars? All I really see are the Dorman type in this size.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Stock Steel Rim options
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Like with these. What the heck are the (71.5, and 20) in the description?
  3. #3 Re: Stock Steel Rim options
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Sorry, Forgot the link and I can’t edit posts.
    Dropbox - Photo Feb 28, 4 52 23 PM.png - Simplify your life
  4. #4 Re: Stock Steel Rim options
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    71.5 is the diameter of the center bore, which is the hole in the middle of the wheel. 20 is the offset, which is the distance from the surface where the lug holes are to the middle of the wheel. Both are in mm.
  5. #5 Re: Stock Steel Rim options
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Thanks for the reply. Do you know what the stock numbers for the 225/55/17 tire size should be?
  1. Steel Rims Help?
    By corxbeans in forum Tires & Wheels
    Last Post: 09-15-2013, 08:44 AM
  2. Stock replacement exhaust options.
    By bigtom9492 in forum Engine
    Last Post: 08-06-2013, 08:56 PM
  3. Stainless steel hoses need help
    By smyoung52 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2013, 08:22 PM
  4. Stock alternator options?
    By xekrubx in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2013, 04:36 PM
  5. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
