Thread: GXP Tire Questions
Results 1 to 6 of 6
  1. #1 GXP Tire Questions
    Sep 2017
    Winneconne, WI
    Has anyone put the same size tires all around on a '08 GXP? The fronts are now 255/45zr18 on factory 8" rims. Why not the same tire on the rear 7" rims?
    Or, is there a 50 series or 55 series that would give better ride quality?
  2. #2 Re: GXP Tire Questions
    Mar 2015
    Tampa, FL
    255 is a bit much on a 7" rim. I have 245s on 7" and id say that's about the limit unless you have plenty of sidewall.
  3. #3 Re: GXP Tire Questions
    Jul 2017
    macomb mi
    yea I would say the same maybe find a gxp at the junkyard and pull the 2 8 inch rims off that?
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  4. #4 Re: GXP Tire Questions
    245/45/18 is the size to run all 4 corners. But I would find 2 more 8in rear wheels so you can do real rotates.
  5. #5 Re: GXP Tire Questions
    Sep 2017
    Winneconne, WI
    Anyone have a pair of stock 8" Grand Prix GXP rims for sale?
  6. #6 Re: GXP Tire Questions
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    I do. PM me.
  1. Tire width questions
    By GTP253 in forum Introductions/Noob Questions
    Last Post: 11-15-2015, 11:41 AM
  2. Couple Tire Questions
    By M7x350z in forum Tires & Wheels
    Last Post: 04-30-2014, 12:06 AM
  3. wheel / tire questions.
    By TJWA07GXP in forum Introductions/Noob Questions
    Last Post: 01-18-2012, 01:41 PM
  4. Tire questions
    By GPGT2004 in forum Tires & Wheels
    Last Post: 07-29-2011, 09:43 PM
  5. Factory gxp wheel / tire questions
    By funkenmiester in forum Tires & Wheels
    Last Post: 05-19-2010, 09:50 PM
