Thread: Lug stud replacement
Results 1 to 8 of 8
  1. #1 Lug stud replacement
    GT Level Member gpbastard's Avatar
    Florida
    Hey guys,
    I have a 2001 GP SE. On the right rear wheel (from the drivers position) the threads on one of the studs is stripped. Can I replace it without removing the bearing hub assembly? In other words, is their enough room in the back to put the stud through the hole w/o something getting in the way? Also, I need a new stud and acorn nut too for it. Where do you recommend I go to buy a new one that's high quality, Dealership?
    gpbastard
  2. #2 Re: Lug stud replacement
    Jul 2010
    Coquitlam,BC,Canada
    This may or may not help.....
    A few years ago I noticed a front lug nut missing, which turned out to be a broken stud. I went to my local parts store and got a new nut and stud. For the stud, they listed "regular length" or "short length". I got the shorter one as it was noted that it could be installed without removing the bearing. Luckily I went to my buddy's shop to use his hoist, cuz that short length stud was not going to go in any which way. Pulled the bearing, installed the stud, put the wheel on..... the stud is so short that you could not get the nut on. FAWK! Ordered the regular length stud and went for lunch. Came back a few hours later and did the job again.
    Regular length stud, Raybestos #2093B
    Short length stud, Raybestos #27711B
    The 2093B is used on the rear, and my app guide does not say anything about bearing removal, so maybe there is more room in the back.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Lug stud replacement
    Florida
    Quote Originally Posted by Bronco Boy View Post
    Thanks for the info. I'm hoping that I don't have to remove the bearing hub.
    gpbastard
  4. #4 Lug stud replacement
    Quincy, Mass
    AutoZone and the like should have them, quality is going to be pretty much the same on all of them. the problem if when a bad mechanic puts the lugs on with the impact gun before they start them by hand and don't realize they crossed the threads.
    No more GP 04 Impala SS Indy:
  5. #5 Re: Lug stud replacement
    Florida
    Quote Originally Posted by Swiggles View Post
    gpbastard
  6. #6 Re: Lug stud replacement
    not sure if the back is like the front, tight to get the new lug in, what we do for the front is cut one side of the backing part off so it can slide past the ring where the studs go. then use a lug nut on backwards ( flat side to the hub) to crank it in place.
  7. #7 Re: Lug stud replacement
    Florida
    [QUOTE=Scottydoggs;1454591]not sure if the back is like the front, tight to get the new lug in, what we do for the front is cut one side of the backing part off so it can slide past the ring where the studs go. then use a lug nut on backwards ( flat side to the hub) to crank it in place Thanks Scotty!
    gpbastard
  8. #8 Re: Lug stud replacement
    Jul 2016
    St. Louis
    This works perfect. I bought OEM studs from GM, little more expensive, but exact match to originals.
  1. Wheel stud
    By Ultra440 in forum Tires & Wheels
    Last Post: 10-17-2014, 06:52 AM
  2. How to replace a lug nut stud.
    By Russosaur in forum Tires & Wheels
    Last Post: 08-29-2012, 03:04 PM
  3. Broken lug nut stud replacement
    By rnovember in forum General Tech Discussion
    Last Post: 05-03-2011, 10:16 AM
  4. Boring but necessary - Stud replacement
    By flash527 in forum General Tech Discussion
    Last Post: 12-03-2010, 10:05 PM
  5. &#@$ing Wheel Stud
    By Abrasive in forum The Rant Forum
    Last Post: 04-01-2008, 05:44 PM
