i was given a set of Goodyear eagles 235/50/18s for helping my friend move they are near new how ever I don't have any 18 inch wheels i didn't want to buy wheels and find out they would rub I'm lowered on vogtlands.
thanks
thanks
Stock is around 26.7" tall
In the title you have 235/50/18 and they are 27.25" tall
In the thread body you have 235/60/18 and they are 29.1" tall
So no, they won't fit.
Oops miss type there 50s I know there taller but there also there also wider I used a calculator already but I'm not sure how much width room I have
Stock width is 8.86 but the 235/50s are 9.25 wide I didn't know if some one else has ran them.
Did my post confuse you? BLAME AUTOCORRECT!
OK thanks I figured that 1/2" taller tire wouldn't made the difference
And it was going to be too wide well thanks again
I run 235-50-18s with lowering springs, they fit fine. I rolled the front fender lips and that took car of any rubbing on big bumps. Its also nice having a little more rubber between me and the road.
I used a hammer a gently folded the fender lip by working my way back and forth. I had to remove the screw at the top of the fender lip holding the inner liner in place. After the lip is folded up the liner is held in place by the lip and the screw is not needed.
My Speedo is abound 1.5 mph slow at 70. Not very noticeable. I usually apply a 5 mph tolerance to my driving speed so to me 1-2 mph is not a big deal.
