transmision slipping
victorca1
hi i have a pontiac gran prix 1998 and i am having problems with the transmision when its cold i put it in gear and it grabs for about 10 sec then starts slipping till it doesnt grab at all and it does a noise in the trans as if it was the steering pump without fluid what can that be?
That would probably be a bad transmission.
Check the fluid level and color. If you have the availability pull the codes even if the light is off. (Some codes to not illuminate the CEL)
